Build to run GTA V on ultra and CPU cooler
Your build is using less than 350 Watts their absolutely no reason to add more fans. (other than the CPU cooler)
https://pcpartpicker.com/parts/compare/corsair-case-cc9011049ww%2Cphanteks-case-phes614pbk/
Welcome to 2015
Sorry first reply was a dud. This case was good 5-10 years ago and still is good to this day, i have had 2 builds based on this cas, one from 7 years ago and one from 1 1/2 years ago and its amazing! Great air flow and easy to build off. So i would rather stay with it but what you say does have truth. Do you have a case in mind that would be a good sub?
thats not the point, the point is to have another fan to keep dust out, where i live its very dusty and the more fans you have blowing out the less dusty it gets and i don't have to be constantly cleaning it.
Your build looks good! One thing though, If it was my money i would replace the case to something newer, like an Enthoo Pro, as Zerk2012 suggested. A side fan is not really necessary, and sometimes disrupts airflow. :)
what about a NZXT Phantom 410? i need something midtower or smaller, and ive only been able to find enthoos in Full.
Yes, that should work. Nice case, too. Good luck!
