Build vs build
PCPartPicker part list: http://pcpartpicker.com/p/FxWmHx
Price breakdown by merchant: http://pcpartpicker.com/p/FxWmHx/by_merchant/
CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor ($279.99 @ Micro Center)
CPU Cooler: CRYORIG H7 49.0 CFM CPU Cooler ($34.50 @ Newegg)
Motherboard: ASRock Z97 PRO4 ATX LGA1150 Motherboard ($89.99 @ Micro Center)
Memory: G.Skill Ares Series 16GB (2 x 8GB) DDR3-2133 Memory ($115.98 @ Newegg)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive ($99.99 @ Micro Center)
Storage: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive ($73.95 @ SuperBiiz)
Case: Corsair 230T Windowed-BLUE ATX Mid Tower Case ($78.99 @ Amazon)
Power Supply: EVGA 850W 80+ Gold Certified Fully-Modular ATX...
your build were over heavy on some parts and had older parts in some spots. the build i going to post i removed the gpu as amd in 3 weeks is dropping there newer r300 line. google the info on there newer cards. the newer cards are going to use less power then the older ones. you dont need a 500g ssd. ram is older model ram. also if your buying at local micro center there is 40.00 instant combo on cpu and mb.
How about this:
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor ($226.99 @ SuperBiiz)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler ($28.95 @ NCIX US)
Motherboard: Gigabyte GA-Z97X-SLI ATX LGA1150 Motherboard ($111.98 @ Newegg)
Memory: G.Skill Ripjaws X Series 16GB (2 x 8GB) DDR3-1600 Memory ($108.98 @ OutletPC)
Storage: Samsung 850 EVO-Series 500GB 2.5" Solid State Drive ($189.99 @ Amazon)
Video Card: EVGA GeForce GTX 980 4GB Superclocked ACX 2.0 Video Card ($544.99 @ NCIX US)
Case: Corsair 200R ATX Mid Tower Case ($56.98 @ Newegg)
Power Supply: XFX XTR 550W 80+ Gold Certified Fully-Modular ATX Power Supply ($61.98 @ Newegg)
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer ($18.95 @ OutletPC)
Total: $1423.74
It'll be great for high end gaming. One GPU is better than 2 GPUs unless you put up with headaches.
Power Supply: EVGA 850W 80+ Gold Certified Fully-Modular ATX Power Supply ($117.99 @ NCIX US)
Total: $910.33
Generated by PCPartPicker 2015-04-18 11:58 EDT-0400
