I just got a Gigabyte 7950 to put into a new rig of used parts I had lying around. I have tested this rig out with an old 4670 I had laying around and it POSTs fine. When the 7950 is installed I hear 3 beeps (1st beep is long, 3rd is short, not sure about 2nd) from the speaker and it doesn't POST. The 7950's fans spin during this so it's definitely getting power.
I had a similar problem with this board several months ago when I was going to put it into a friend's build. Back then I was using a 7770 and the build would not POST when the monitor was connected with DVI, but it POSTed fine when connected with VGA. However, the 7950 does not have VGA so I can't POST. I connected the 7950 with both HDMI and DVI and it failed. 4670 connected with VGA or HDMI works fine. Weird problem, no idea why this is happening.
Sometimes I don't even get any beeps...
tl;dr Build boots fine when using 4670 or 7770 with a VGA connection. Will not POST with a 7950 connected with DVI or HDMI. Why?
Parts:
MSI P67A C43 B3
i3 G550
2x2GB Corsair Vengeance 1600MHz RAM
Gigabyte 7950
600W OCZ PSU
Booting from USB Drive
The build is for mining, that is why I'm using a Celeron.
Parts:
MSI P67A C43 B3
i3 G550
Gigabyte 7950
600W OCZ PSU
