Building $850 CAD PC Need Advice/Suggestions (First Build)
michaeltbb8
13
I would like to build a $850 PC in the summer. I have made a list of my parts that I am going to use on pcpartpicker ComputerBuild. Some of the games that I'd like to play on it are pubg, project cars 2, minecraft, BeamNG.drive and GTA 5. Does this seem like a good build for me. Is this future proofed (will be able to play the newest games for years to come and upgrade-able)? Are all parts compatible. Is this the best bang for my buck. Would I get more if I bought a pre-built pc in this price range? All feedback is appreciated. Thank you.
Pretty decent, but I would make a few changes. Especially get dual-channel RAM.
CPU: AMD - Ryzen 3 1200 3.1GHz Quad-Core Processor ($117.87 @ Amazon Canada)
Motherboard: Gigabyte - GA-AB350M-DS3H Micro ATX AM4 Motherboard ($78.99 @ PC-Canada)
Memory: Team - Vulcan 8GB (2 x 4GB) DDR4-2400 Memory ($105.99 @ Newegg Canada)
Storage: Crucial - MX500 250GB M.2-2280 Solid State Drive ($89.76 @ shopRBC)
Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($54.25 @ Vuugo)
Video Card: Gigabyte - GeForce GTX 1060 3GB 3GB Mini ITX OC Video Card ($309.99 @ Memory Express)
Case: Deepcool - TESSERACT SW ATX Mid Tower Case ($44.99 @ Newegg Canada)
Power Supply: Corsair - CXM (2015) 450W 80+ Bronze Certified Semi-Modular ATX Power Supply ($44.99 @ Memory Express)
Total: $846.83
Generated by PCPartPicker 2018-05-27 16:34 EDT-0400
PSU tier list reference - https://linustechtips.com/main/topic/631048-psu-tier-list-updated/
michaeltbb8
13
I like your suggestions. I just have one question, what is dual-channel ram? Is it just simply having 2 ram sticks or is it more than that?
rontonomo
Respectable
Jun 26, 2016
324
33
dual channel ram means that it runs on two channels so if you only use 2 sticks of ram they need to be in specific slots since most boards that are dual channel actually have 4 slots. just make sure to check your mother board instructions to make sure that you put them in the right slots if only using two sticks of ram.
