[SOLVED] Building a budget gaming PC. I need help with my parts.
Sep 11, 2019
4
Hi I am building a budget gaming PC. I am starting to pick out parts. I have in my list (Not including input/output devices) is
CPU: i5-9400f 150$
MoBo: Gigabyte Z390 GAMING X 140$
GPU: PNY GeForce GTX 160$
Case: Fractal Design Focus G Tower 70$
Storage: Seagate Barracuda 1 TB Internal HDD 40$
Ram: CORSAIR - VENGEANCE LPX Series 16GB (2x8GB): 60$
PSU: Cooler Master Power Supply Master Watt Lite 500w80 84$
CPU Cooler: Cooler Master Hyper 25$
I was wondering if there is any better or cheaper equivalent.
thanks
PC Tailor
Dignified
Herald
PCPartPicker Part List
CPU: AMD Ryzen 5 2600 3.4 GHz 6-Core Processor ($128.96 @ OutletPC)
Motherboard: MSI B450-A PRO ATX AM4 Motherboard ($95.75 @ OutletPC)
Memory: Team T-FORCE VULCAN Z 16 GB (2 x 8 GB) DDR4-3200 Memory ($64.99 @ Newegg)
Storage: Crucial MX500 1 TB 2.5" Solid State Drive ($107.89 @ OutletPC)
Video Card: MSI Radeon RX 580 8 GB ARMOR OC Video Card ($159.99 @ Newegg)
Case: Fractal Design Focus G ATX Mid Tower Case ($55.88 @ Amazon)
Power Supply: Corsair CX (2017) 550 W 80+ Bronze Certified ATX Power Supply ($59.99 @ Newegg)
Operating System: Microsoft Windows 10 Home OEM 64-bit ($99.89 @ OutletPC)
Total: $773.34
Generated by PCPartPicker 2019-09-11 16:49 EDT-0400
AMD I believe gives you better value for money.
Better parts than you have already mentioned.
Remeca
Upstanding
Aug 30, 2019
281
38
240
5
If you're going budget, AMD is worth looking at from a cost to performance perspective. For example, a ryzen 5 2600x is very competitive in that price range, with more threads.
PC Tailor
Dignified
Herald
Welcome to the forums my friend?
What is your budget and location?
What GPU are you getting (it just says GTX)?
Definitely upgrade the PSU.
You may want to consider an SSD, it's practically a must nowadays.
Also what speed RAM is it?
You shouldn't need an aftermarket CPU cooler.
Sep 11, 2019
4
The only reason i put a i5-9400f was because i have had macs my whole life but i'll check out AMD.
Sep 11, 2019
4
"What is your budget and location?"
Around 800$ and i'm from the USA
"What GPU are you getting (it just says GTX)?"
AMD Radeon RX 570 (4GB) sorry, i didn't know how much was important.
"Definitely upgrade the PSU."
Any recommendations?
"You may want to consider an SSD, it's practically a must nowadays."
"Also what speed RAM is it?"
2.4Ghz
"You shouldn't need an aftermarket CPU cooler."
Ok
PC Tailor
Dignified
Herald
Total: $773.34
Sep 11, 2019
4
Case: NZXT H500 ATX Mid Tower Case ($69.99 @ Best Buy)
Total: $787.45
Generated by PCPartPicker 2019-09-11 16:48 EDT-0400
I'll put this into my spreadsheet. Thx :)
Sep 9, 2019
15
CPU: i5-9400f 150$
thanks
i personally prefer as a budget and moderately high end case
the h150 by nzxt
