Building a computer, need help!
iAmPhoReal
24
iAmPhoReal
24
Just browsing the web and league of legends. I was on a 400 budget for the computer itself, and I ended up w/ 405. then there was another 100 for the monitor and 45 for speakers plus keyboard & mouse.
iAmPhoReal
24
Too lazy to do mailin rebate, but okay I'll buy it. Muffin, could you tell me if I'm missing anything, such as a cable or sound card or something. And could you tell me if everything's compatible?
melikepie
1,612
i never heard of that psu brand but to be safe you should buy a psu from corsair or xfx
that cpu should be good but i would say buy a 455 rana
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103911
you can unlock a fourth core but you will need a am3 or am3+ board
truegenius
BANNED
pentium 620 is like i3 but without ht, aes, less clock speed, with intel hd instead of hd2k (which doesn't matter as you are getting a dgpu), and only have mc of upto 1066mhz with duel channel support.
Overall a great build.
Psu upto 300 watt is enough.
As you have 32bit os then you are limited to 4gb of ram, so 2x2gb will give you double bandwidth in comparision to single.
I haven't played league of legends so i don't know about that.
