[SOLVED] Building A new Pc and need help with cooling
KeithK2006
86
4
4,545
Hey Guys,
I recently started to come up with some parts to build my new PC and I need to find a nice liquid cooler and fans and the parts are as follows:
-Crucial MX500 500GB 3D NAND SATA 2.5 Inch Internal SSD
-MSI MPG Z390 Gaming Edge AC LGA1151 (Intel 8th and 9th Gen) M.2 USB 3.1 Gen 2 DDR4 HDMI DP Wi-Fi SLI CFX ATX Motherboard
-Patriot Viper Gaming RGB Series DDR4 Dram 3200MHz 16GB Kit - Black - RGB Color Profiles
-Intel BX80684I59600K Boxed Core i5-9600K Processor, 9M Cache, up to 4.60 GHz 3.7 6
-Seagate Barracuda 2TB 3.5-Inch SATA 6 Gb/s Internal Hard Drive (ST2000DM006)
-ZOTAC Gaming GeForce RTX 2080 Twin Fan Graphic Card ZT-T20800G-10P
-Thermaltake PS-SPR-0700NHFAWU-1 Smart 700W 80 Plus 256 Color RGB Fan ATX 12V 2.3 Kaby Lake Ready Power Supply
-CORSAIR Carbide SPEC-06 RGB Mid-Tower Gaming Case, Tempered Glass- White
My case comes with 2 fans and can support 360mm liquid cooler but they come out as to expensive for me. If anyone can find me a functional liquid cooler and fans (that are good for gaming) that would be awesome!
Thanks!
A good 360 rad will be around 150$ for anything decent. You could get away with 100$-ish for a 240/280 rad. You're getting good components man, don't cheap out of your cooling, get something of quality that will fit the quality of the rest of your components... Since you're getting a Corsair case, you might want to look into the Corsair Hydro H110 or H110i so the RGB can sync up to the case and fans. Alternatively, a good aie cooler like the Dark Rock 4 or Dark Rock Pro 4 can provide excellent cooling as well.
Reactions: KeithK2006
Oh okay Thanks!
I found a 240mm one for $150 and 360mm for $209
240mm
360mm
Would the 240mm be sufficient for my system? If so will it fit in my case?
I also have 4 Corsair Air Series AF120 LED Quiet Edition High Airflow Fans to decipate the heat will i need to buy more for my parts?
Thanks
