Building a new PC. Help!
AnakinGuy12
65
Ok, I'm looking into building a new PC. I've done this in the past, but this one is different. This is more of a budget computer. I will be gaming and doing limited video editing on it. I want to be able to play any game on at least medium settings. My max budget is about $600. (I can probably go to about $650, that gives you a little more room). So can you guys give me a list of good parts that will be within my budget? Please help!
CPU: AMD FX-6300 3.5GHz 6-Core Processor ($133.79 @ Amazon)
CPU Cooler: Cooler Master Hyper 212 Plus 76.8 CFM Sleeve Bearing CPU Cooler ($19.99 @ Newegg)
Motherboard: ASRock 970 Extreme3 ATX AM3+ Motherboard ($89.98 @ Outlet PC)
Memory: G.Skill Sniper 8GB (2 x 4GB) DDR3-1600 Memory ($43.98 @ Outlet PC)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($69.98 @ Outlet PC)
Video Card: XFX Radeon HD 7870 2GB Video Card ($214.99 @ Newegg)
Case: Zalman Z9 ATX Mid Tower Case ($34.99 @ Newegg)
Power Supply: Antec Neo Eco 520W 80 PLUS Certified ATX12V / EPS12V Power Supply ($39.99 @ Newegg)
Optical Drive: Lite-On iHAS124-04 DVD/CD Writer ($16.98 @ Outlet PC)
Total: $664.67
(Generated by PCPartPicker 2013-02-02 17:46 EST-0500)
This is super unbalanced.
slow single channel RAM
cheap low quality motherboard
SSD to small to use
unreliable awful PSU
GPU that won't play games past low settings.
For $600 you can usually get high settings out of a build.
The build posted above is great!
The fx 6300 beats the fx 8120 in gaming.
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler ($33.24 @ Amazon)
Motherboard: ASRock 970 Extreme3 ATX AM3+ Motherboard ($84.99 @ Amazon)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive ($69.98 @ Outlet PC)
Video Card: Sapphire Radeon HD 7850 1GB Video Card ($154.99 @ Newegg)
Case: Corsair 200R ATX Mid Tower Case ($34.99 @ Newegg)
Power Supply: XFX 550W 80 PLUS Bronze Certified ATX12V / EPS12V Power Supply ($65.99 @ Amazon)
Total: $638.93
(Generated by PCPartPicker 2013-02-02 18:07 EST-0500)
Would it be more wise to just upgrade my current gaming system? Current Build:
CPU: AMD FX 6100 at 3.3 Ghz
Mobo: Asus M5A97 LE 2.0
RAM: 8GB G-Skill RipjawsX
Video Card: Asus HD 7770 2GB
Power Supply: Corsair 600W
I don't need to list the case and optical drive, that is ok.
Do you think I would be fine just sticking with my current build?
If you are going to spend any money on that system. Buy a nice beefy graphics card. You shouldn't need a new psu 600w is plenty unless you plan on Adding more then one graphics card. and 8 gigs of Ram is OK. If you are doing a lot of video editing and stuff. adding more RAM might not hurt.
I edit sometimes. Nothing extreme and nothing that I can't wait an extra 10 minutes to render. If I was going to buy a new Graphics Card what would you recommend? No more than $200. I ran Crysis 3's beta on High today with no lag. (Very High is the highest settings, therefore I ran it just under the highest settings).
Step it up to an HD 7870 (it sits around the $200 price point) or a HD 7850 if you want to be safe with your budget. Again, a little more RAM might not hurt, but that's totally optional.
Do you OC? (CPU, GPU, both or neither?)
I don't overclock. (I'm more than open to it, I'm just really not sure how to do it). But my GPU is factory overclocked.
Ok, I have a friend that want's my 7770. I could trade my 7770 for his 460. But I stick with what I have. I may even wait until the 8000 series comes out. Thanks for the responses. 😀
