Building a new system and MOBO is my first stop!
xLei
39
So...my desktop died a few months ago, very very sad, it was a slimline which means limited space...lol. Now, I bought a new tower, a new PSU and they are just sitting there, soon I am going to get about $400US ($800Bds, my currency) in my hands and I want to delegate that for Computer rebuild usage!
This is where you come in. I would suggestions for a good performance MOBO that isn't too pricey! My next stop is going to be a CPU, so I need to stretch that 400 bucks between those two and then I can always work on the RAM later and the Operating system (since I was told by Microsoft that I will need to purchase one).
I want something with good onboard graphics until I can save up for a good graphics card.
I guess I should say that I use my computer to play games, use architect CAD software and for programming as well...So anything you can suggest will be great. If I can get MOBO, CPU and RAM out of that 400 dollars I'll be glad, but I won't mind just the CPU and MOBO.
Reason I'm here is because I had bought a BIOSTAR A780L3B board in late November 2012 and now I'm stuck with no desktop, I dunno if it's because the board was cheap or what, but I just hate knowing I spent that money to rebuild my computer and a year and...2-3 months later I need to repurchase everything including an OS which I spent hella money on but now is useless once I do another rebuild...Yay me....Plus I hate working my laptop so hard.
So help please. =)
Whatever you suggest I'll also read reviews on. Thank you in advance. =)
Don't start with the motherbaord - start with the CPU. that is what you have to decide first. THen you get a mobo that will support your CPU.
As for graphics, all the Intel and AMD CPus recently (with the exception of some at the very low end (Pentium) and some at the high-end (Enthusiast and Xeon) have built-in graphics processors. Not great ones, but sufficient ones to get off the ground.
In reviews I've read, motherboards are basically performance-neutral.
If you have the OS disk, you can probably re-install it on the new computer. That should free up about US$100 for you.
How's this for a beginning?
Nice CPU, onboard graphics, good motherboard and 8GB of memory. Low power. You'll be able to get away with 350-400W PSU until...
Nice CPU, onboard graphics, good motherboard and 8GB of memory. Low power. You'll be able to get away with 350-400W PSU until you decide to add a video card.
CPU: Intel Core i5-4590 3.3GHz Quad-Core Processor ($199.98 @ SuperBiiz)
Motherboard: ASRock Z97 PRO3 ATX LGA1150 Motherboard ($99.99 @ Newegg)
Memory: G.Skill Ripjaws Series 8GB (2 x 4GB) DDR3-1600 Memory ($73.99 @ Newegg)
Total: $373.96
I love this response. The i5-4590 is an incredible CPU, but if you can, stretch your budget to fit this:
CPU: Intel Xeon E3-1230 V3 3.3GHz Quad-Core Processor ($249.98 @ SuperBiiz)
Motherboard: Gigabyte GA-H97M-HD3 Micro ATX LGA1150 Motherboard ($84.99 @ Mwave)
Total: $334.97
The Xeon, as it is hyperthreaded (8 cores essentially), will help with your multitasking, programming, and CAD stuff and will last longer than a simple 4-core i5. It is essentially an i7-4770.
What is your old RAM? It might plug right into this.
You're very kind, but now he needs a graphics card. :) I guess he has a little wriggle room to buy a low-end graphics card comparable to the onboard graphics of the i5 processor if he can re-use his memory?
Edit: This $50 (after current rebate) video card will outperform the Intel graphics in the i5 processor: http://www.newegg.com/Product/Product.aspx?Item=N82E16814150712
This will perform about on par with an i5's integrated graphics, and then you can upgrade in the future:
Video Card: PowerColor Radeon HD 5450 1GB Video Card ($9.99 @ Newegg)
Total: $9.99
It will work fine for 2D CAD and some light 3D stuff, but after that, onboard graphics and this don't stand much of a chance.
Ha, that's funny, I just updated my earlier response with a $50 video card. Never thought I'd see the day of a $9.99 video card. And to think that I had a build way back when with one of those in it. Maybe not a Powercolor - but a 5450 nevertheless. Wow, brings back memories.
Thank you thank you all so much!
BTW She* I'm a She, lol.
I can't thank you guys enough! I'll check out some reviews and. Which I could make all your answers the answer. Or atleast have the option to "Thank you". Aw well....THANKS! =D
Just select Karsten's as the answer he helped more than me. If you want to thank us just click the up arrow thing and that helps a bit!
You're welcome. Good luck!
