I am building a gaming rig with a 550 watt antec psu and it has removable plugs but theres also a direct cable that comes from the unit it has a 24 pin connector i get that but theres a pcie connector. Theres also another PCIE connector thats colored red that removes in or out. I ahve a radeon 7970 sapphire 3gb 500 watt minimum
What plug should i plug it into and whats with both i heard of 12volt rail x2 is this what it means theres 2 connectors and im really confused.
Also I have a 550 watt psu with a roswil blackhawk tower with 5 fans. when it needs a minimum of 500 watts is that mean the card uses that becuase the cpu is 77 wats its a i5 so whats the deal there.
