Building a PC around Christmas and I need final suggestions and comments
  • Thread starter Thread starter Guest
  • Start date Start date
G
Guest
Guest
Just want to know whether this is a balanced build for 1080p gaming at ultra and if there are any obvious gaps to save money without sacrificing much performance. I also need to know if this is EVERYTHING I will need to buy (other than the heat paste stuff you put on the CPU). http://au.pcpartpicker.com/p/p6Dqt6
Well instead of getting a $215 mobo and a $300 cpu, you should go for a i5-6600k since it is way better and more future proof and you can get a good mobo for it for around 140-180$ so the price will even itself out and you will get a way better performance overall. Also with it you should go for DDR4 since again that is the future and the prices are quite similar again. Maybe you might want to go for 2x8gb instead of 2x4gb so that you save yourself the hassle of getting more ram in 1-2 years.
I don't intend to go any more expensive than the price at the moment and swapping those parts out I believe will make the overall price higher.
How does this look? It's more expensive with a hella load more.
CPU: Intel Core i5-6500 3.2GHz Quad-Core Processor ($295.00 @ Umart)
Motherboard: Gigabyte GA-H170-GAMING 3 ATX LGA1151 Motherboard ($199.00 @ Umart)
Memory: G.Skill Ripjaws V Series 16GB (2 x 8GB) DDR4-2400 Memory ($150.00 @ IJK)
Storage: Samsung 850 EVO-Series 120GB 2.5" Solid State Drive ($89.00 @ Storm Computers)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($75.00 @ PCCaseGear)
Video Card: PowerColor Radeon R9 390 8GB PCS+ Video Card ($475.00 @ CPL Online)
Case: Fractal Design Define S w/Window ATX Mid Tower Case ($155.00 @ CPL Online)
Power Supply: SeaSonic 650W 80+ Gold Certified ATX Power Supply ($119.00 @ Umart)
Operating System: Microsoft Windows 10 Home OEM (64-bit) ($145.00 @ CPL Online)
Wireless Network Adapter: TP-Link TL-WN781ND 802.11b/g/n PCI-Express x1 Wi-Fi Adapter ($16.00 @ Mwave Australia)
Monitor: BenQ BL2420PT 60Hz 23.8" Monitor ($399.00 @ CPL Online)
Keyboard: Ducky DK9008 Shine 3 Blue LED Backlit (Red Cherry MX) Wired Standard Keyboard ($129.00 @ CPL Online)
Mouse: Logitech G502 Wired Optical Mouse ($61.00 @ CPL Online)
Total: $2307.00
Generated by PCPartPicker 2015-11-12 21:23 AEDT+1100
how good is bl2420pt monitor? i ma planning to buy the same
