Hello as the tittle says Im building a PC, but I need to know something... so I been using a h100i GTX and my last PC and I was wondering If I should keep it, It has almost 1h year and half never maxed the PUMP or FANS always used them at the lowest setup.. and I dont know if I should change cause I would only change it for a hyper evo 212. wont upgrade would be better to keep it and use it on my next setup or change it because it already have 1year and half?
Also, is the Asus z210 Strix a good MOBO?
