[SOLVED] Building a PC for a Friend. Are These Parts Compatible?
xsplattermusic
52
PCPartPicker Part List
CPU: AMD Ryzen 5 3600 3.6 GHz 6-Core Processor ($174.99 @ Amazon)
CPU Cooler: Stock Cooler that comes with the CPU ^^^
Motherboard: MSI B450 TOMAHAWK MAX ATX AM4 Motherboard ($114.99 @ B&H)
Memory: Corsair Vengeance LPX 16 GB (2 x 8 GB) DDR4-3000 Memory ($77.99 @ Best Buy)
Storage: Western Digital Caviar Blue 1 TB 3.5" 7200RPM Internal Hard Drive ($44.99 @ Adorama)
Video Card: Asus GeForce RTX 2060 SUPER 8 GB STRIX GAMING Advanced Video Card ($449.99 @ B&H)
Case: Corsair SPEC-DELTA RGB ATX Mid Tower Case ($79.99 @ Best Buy)
Power Supply: Corsair CXM 650 W 80+ Bronze Certified Semi-modular ATX Power Supply ($89.98 @ Newegg)
Operating System: Microsoft Windows 10 Home OEM 64-bit ($99.99 @ B&H)
Total: $1170.11
Generated by PCPartPicker 2020-02-08 23:46 EST-0500
Any suggestions, or anything wrong with this build? I just want to make sure!
Thank you so much.
Mind giving me a suggestion? I don't quite get what you mean
https://www.msi.com/Motherboard/support/B450-TOMAHAWK-MAX/#support-mem-19
this is the memory QVL the Qualified vendors list. these modules have been factory tested to work at the listed speeds and voltages.
they ARE NOT, repeat ARE NOT the only modules that will work with the board, only a list of what MSI had on hand to test with. the length of the list ensures broad compatibility.
RAM speeds of 3000 are the suggested speeds for ryzen 1 CPU's, the ryzen 2 chips like 3200, and ryzen 3 3600. all ryzen CPUs love all the bandwidth you can give them and the modules you selected are slow in comparison to what the CPU can use, in this case 3600 and above. some modules...
looks fine save the RAM. its a bit slow look to 3600mhz modules for the ryzen 3 series.
that board is Ryzen 3 ready out of the box, disregard the PCPP warning about an update, the MAX means the update has already been installed on MSI boards.
Total: $1170.11
Thank you so much.
Just make sure your RAM is in the memory compatibility list of your motherboard otherwise XMP speed might not work which is the case of many users here.
RAM speeds of 3000 are the suggested speeds for ryzen 1 CPU's, the ryzen 2 chips like 3200, and ryzen 3 3600. all ryzen CPUs love all the bandwidth you can give them and the modules you selected are slow in comparison to what the CPU can use, in this case 3600 and above. some modules on the list have been tested to over 4200mhz.
CPU Cooler: AMD Wraith Max 55.78 CFM CPU Cooler ($37.20 @ Amazon)
Memory: Corsair Vengeance LPX 16 GB (2 x 8 GB) DDR4-3600 Memory ($81.99 @ Amazon)
Total: $1174.11
Generated by PCPartPicker 2020-02-09 00:14 EST-0500
Total: $1174.11
So getting this will be fine?
https://pcpartpicker.com/product/7C...-2-x-8-gb-ddr4-3600-memory-cmk16gx4m2c3600c20
(sorry for the late reply)
