Hi everyone,
Please assist me in building a PC that would be a good investment for the next coming years!
I want a configuration that would be strong and as quiet as possible, but also maintaining costs and installing dificulty at a minimum. So a balance of those.
My work consists of running tests on virtual machines locally, editing videos and casually playing games ( Dota 2, LoL, The Witcher 3 etc ).
Also i am not planning on doing any overcloaking on the components.
What i got at the moment:
EDIT:
Approximate Purchase Date: within 60 days
Budget Range: around $2000
System Usage from Most to Least Important: Virtualization, Video editing, Gaming
Are you buying a monitor: no
Parts Preferences : look above
Overclocking: No
Do you need to buy OS No
SLI or Crossfire: No
Your Monitor Resolution: 2,560 x 1,440
Thank you!
- 2 monitors Asus VG27AQ ( 27 inch, 1440p, 165mhz )
- 2 Sata 3 SSDs ( 1TB and 120gb )
- 1 HDD 2tb 7200 RPM
- In Win G7 case with standard ventilator
- GTX 970 video card ( but it has only mini DP and it is not compatible with Asus cause i won't be able to get sufficient bandwidth to push 144hz at 1440p )
- PSU: Corsair RMx Series RM650x
- Video card: RTX 2070 super ( does it have to be an OC variant like Asus GeForce RTX 2070 Super Overclocked 8G EVO ? ) or RTX 2080 super
- CPU: Ryzen 3900x
- CPU cooler: Noctua NH-D15
- SSD for OS: Adata XPG SX8200 Pro (1TB)
- Motherboard: ASUS TUF GAMING X570-PLUS or GIGABYTE X570 AORUS ELITE
- RAM: 4 x Patriot Viper Steel 16GB DDR4 3200MHz CL16 1.35v ( total of 64gb RAM )
- Case: Fractal Design Define 7 Gray Light Tempered Glass (FD-C-DEF7A-08)
EDIT:
Overclocking: No
Thank you!
