Building a PC, is it good? Help appreciated!
joonho098
Hi! This is my build:
CPU: Intel - Core i7-7700K 4.2GHz Quad-Core Processor
CPU Cooler: Corsair - H100i v2 70.7 CFM Liquid CPU Cooler
Motherboard: MSI - Z270-A PRO ATX LGA1151 Motherboard
Memory: G.Skill - Trident Z RGB 16GB (2 x 8GB) DDR4-2400 Memory
Storage: WD 1TB Caviar Blue HDD & Samsung 850 EVO-Series 250GB 2.5" Solid State Drive
GPU: GTX 1080 Ti (haven't decided which 1080 ti i want yet, leaning towards the msi gaming x)
Case: NZXT - S340 (Black) ATX Mid Tower Case
PSU: EVGA - SuperNOVA G2 750W 80+ Gold Certified Fully-Modular ATX Power Supply
Will be using this computer for gaming, just want to make sure all parts are compatible, and if there are any better alternatives. Any help is greatly appreciated!
Danny_112
69
8
Perfect configuration ! has for the GPU, I would go with the MSI Gaming X, it's cooler
is top notch, quiet and efficient.
The HD change for a WD Caviar Black.
Memory: it's not really worth it to go with 3200mhz vs 2400mhz, unless you work
a lot with Adobe Photoshop, and only a hand full of App's and games,
just decent 2400mhz memory will suffice, and you can oc it to around 2800..., 16 Gig " 2 x 8 gig" , or 2 x 16 gig, if you
get a real good price.
joonho098
Haha yeah, probably gonna go for the msi card then! :wahoo:
Higher RAM makes cpu overclocking better. Slight performance increase + better overclocking, does not harm the pocket for a few more bucks at that price point.
