Building a PC. Need Advise
Yeah looks good, War Thunder is well optimized. If you plan on playing in Realistic or Simulator mode (or doing historical battles), look into a joystick like the Logitech Extreme 3D Pro.
Edit: Overclocking your CPU should remove any and all CPU bottlenecks if they arise while playing other more cpu intensive games.
have a look at this, it´s better if you wanna upgrade in future, the am3+ socket is dead:
CPU: Intel Core i3-6100 3.7GHz Dual-Core Processor ($110.99 @ SuperBiiz)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler ($24.38 @ OutletPC)
Motherboard: Gigabyte GA-B150M-DS3H Micro ATX LGA1151 Motherboard ($65.38 @ Newegg)
Memory: Crucial 16GB (2 x 8GB) DDR4-2133 Memory ($59.99 @ Adorama)
Storage: Kingston SSDNow V300 Series 240GB 2.5" Solid State Drive ($69.99 @ Adorama)
Video Card: MSI GeForce GTX 950 2GB Video Card ($99.99 @ Newegg)
Case: Thermaltake Commander G41 ATX Mid Tower Case ($39.99 @ Newegg)
Power Supply: EVGA 500W 80+ Bronze Certified ATX Power Supply ($43.99 @ SuperBiiz)
Operating System: Microsoft Windows 10 Home Full - USB 32/64-bit ($117.99 @ SuperBiiz)
Total: $632.69
Generated by PCPartPicker 2016-08-03 05:31 EDT-0400
This windows version is not bundled to the hardware and can be installed on any further system you buy (just one at a time)
gtx950 is better than the 750ti
at least 250GB is recommended, better get a samsung 850evo if you can
Joystick is check still have to figure out how to calibrate it. Any movement in a direction takes a few seconds..
I have a good .blk setup file for the Logitech Extreme 3D pro on War Thunder.
If you remind me by instant message, I can send it to you when I get to my computer. I've been able to get 12 kill streaks on what used to be a basically impossible to use device.
So yeah, there is hope for the joystick my friend. Good luck in the air.
I recommend something along the lines of this, although it can be improved greatly.
That power supply is a damn fire hazard, and the SSD is not very good.
Some good alternatives are the Seasonic S12II 520w and the Sandisk SSD PLUS which are both high quality and reliable. The V300 is painfully generic, offering the same performance as other drives which either go for cheaper, or those that perform better for the same price.
I'll post a build below.
Compared to Helpstar's build, this includes a better quality power supply that won't start an unwanted fireplace (^.^), better quality RAM, a case with better build quality in terms of materials and a smaller form factor, and a better SSD for $20 more. Well worth it in my opinion.
PCPartPicker part list: http://pcpartpicker.com/list/wDcDxY
Price breakdown by merchant: http://pcpartpicker.com/list/wDcDxY/by_merchant/
Motherboard: Gigabyte GA-H110M-A Micro ATX LGA1151 Motherboard ($47.98 @ Newegg)
Memory: G.Skill Ripjaws V Series 16GB (2 x 8GB) DDR4-2666 Memory ($62.99 @ Newegg)
Storage: Sandisk SSD PLUS 240GB 2.5" Solid State Drive ($69.99 @ B&H)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($47.49 @ OutletPC)
Case: Cooler Master N200 MicroATX Mid Tower Case ($45.99 @ SuperBiiz)
Power Supply: SeaSonic S12II 520W 80+ Bronze Certified ATX Power Supply ($58.99 @ SuperBiiz)
Operating System: Microsoft Windows 10 Home OEM 64-bit ($85.89 @ OutletPC)
Total: $654.68
Generated by PCPartPicker 2016-08-03 08:27 EDT-0400
Memory: G.Skill Aegis 8GB (2 x 4GB) DDR4-2400 Memory ($34.98 @ Newegg)
Storage: Patriot Torch LE 240GB 2.5" Solid State Drive ($56.99 @ Amazon)
Other: 4GB RX 480 ($200.00)
Total: $635.81
Generated by PCPartPicker 2016-08-03 12:25 EDT-0400
Note that you're unlikely to actually find an RX 480 for $200.
Most are retailing for around the $239+ mark at least, which makes it a pain for budgeting!
Additionally, I think it's a little overkill for War Thunder! 😉
"Ripple at +12V is on the high side at full load
Not Haswell ready (according to Intel's testing procedure)
Low hold-up time
Not-so-quiet operation"
Hold up time is essential in a good quality power supply, and high ripple at full load is also an issue when it comes to stability.
The Haswell ready point is also a large concern....
and where did you see the fire? Because it´s not that good, doesn´t mean that in a normal not overclockable system, it would burn down. The ripple at full load: this system will never reach full load. even then , it wouldn´t burn.
haswell readyness proven in the field. The Intel unofficial leaked compatibility tool just says, it isn´t haswell ready. Doesn´t mean anything
To be clear, it´s not the best you could get, but it´s the best for this price and wattage. plus 3years warranty
http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story6&reid=351
Haswell processors have a new sleep state that isn't compatible with previous generation power supplies, although Skylake uses the same sleep state. It's sleep power draw is substantially lower compared to previous generations and can trigger uvp and force a system reset if the power supply is not compatible.
Intel undergoes these tests to make sure that the power supply doesn't screw with their components, the 500B failed in this regard.
I don't mean a literal fire, I mean that figuratively, in that it can fry components due to the above mentioned reason. If you spend an extra $15 or so to get a Seasonic S12II it is definitely worth it, as it gives you much better voltage regulation and a better OEM.
http://www.overclock.net/t/1500086/why-you-should-not-buy-an-evga-400-600-and-500b-600b
there are two psus: one not rated as bronze, the 500W and the one I suggested, the 500B.
I know the haswell/skylake C6 / C7 low power thingy, but the 500B works with it.
I would go for a PSU which has at least a warranty of 5years.
Is the seasonic s12II 520W haswell ready? It´s just ATX version 2.2
http://www.overclock.net/t/1393042/seasonic-s12ii
the power states could be disabled in bios though to be sure
or spend another 10$ to get haswell ready M12II 520W
The M12II is essentially the same as the S12II with modular cables.....
Same platform, same components; virtually no difference apart from cable design, so I don't see why the S12II wouldn't be haswell ready either, especially considering it's good voltage control.
Edit: "Older or bargain basement power supply units may be unable to achieve this, and might become unstable or trigger a UVP/OVP shutdown once the system enters the C6/C7 power states."
This includes the 500B due to the poor ripple regulation that it suffers from at high load.
Intel does not... oh well, not gonna pursue this any further! :)
The short story is that the EVGA still has lower quality components and capacitors, while the Seasonic is higher quality, and I think it is definitely worth the extra $20 to ensure you are getting a quality product.
Remember that a PSU is the most crucial part of a system, if that breaks down, the whole lot is kaput until you can find a new one. In some cases power supplies with poor voltage regulation even fry components if over volted. 😱
