Building a PC, need help with motherboard
Cameron6399
88
Hi,
I'm building a PC from old/new parts, and already have/have chosen most of the components, however, I have no knowledge/understanding of motherboards...
So here is a list of the parts I already have/will be getting -
- ASUS STRIX GeForce GTX 960 Graphics Card
- HyperX FURY Series (2 x 8 GB) DDR3 1866 MHz
- Intel core i5-4440 CPU @ 3.10ghz (From old PC, so no website)
- And all other parts from an Alienware X51 R2 gaming PC
However, I have been told that the mother board from the alienware does not fit into any other case, is this true? If not then my main question is -
What motherboard will I need? preferably i'd like it to have red on it (It's the lights ill be going for) and it will need to fit into the NXZT Source 340 case.
Thanks, feel free to ask questions if I haven't explained it very well.
PCPartPicker part list: http://uk.pcpartpicker.com/p/dsnqbv
Price breakdown by merchant: http://uk.pcpartpicker.com/p/dsnqbv/by_merchant/
Motherboard: MSI B85-G43 GAMING ATX LGA1150 Motherboard (£78.82 @ Amazon UK)
Total: £78.82
Generated by PCPartPicker 2016-03-02 17:43 GMT+0000
Atx motherboard, non overclocking chipset, red, cheap. I hope that helped, if you want to know anything else just reply :)
Total: £78.82
I would do that yes, but it is out of my budget, I only want to spend a max of £200 on the Graphics card, if you kind a better one for around that price it would be appreciated?
http://www.amazon.co.uk/PNY-GDDR5-Ge-Force-Graphics-Card/dp/B016XK8WPU/ref=sr_1_6?ie=UTF8&qid=1456947830&sr=8-6&keywords=960+4+gb
- PNY card
http://www.amazon.co.uk/Nvidia-GeForce-Graphics-Express-Display/dp/B00UJLDVJC/ref=sr_1_1?ie=UTF8&qid=1456947830&sr=8-1&keywords=960+4+gb
-ASUS Strix
