Everything looks good except the power supply, switch it out for something like an EVGA SuperNOVA NEX 650W 80+ Gold. The CX range from Corsair use cheaper parts compared to other Corsair power supplies
-changed the FX to a much stronger i5
-The Z97p-d3 is very cheap in the uk right now
- 8gb ram is enough
- changed the gtx 970 to one by galax, probably the best 970 on the market right now
- changed the power supply to a quality rebranded seasonic unit
- i5 +mobo instead of FX6300 for better cpu performance
- 8gb instead of 16gb, since mostly 8gb is more than enough for gaming/general use unless you are doing some heavy editing work. I assume you are building this rig for gaming because of the GTX 970.
- 7200 rpm harddrive instead of 5400 rpm
- better psu
- windows 8.1 instead of windows 7 for better performance
i recommend a titan... there alright for this sort of price range
This is a joke right?
Yeah it was... all in all i would say you're recommended builds are solid. Question .. If you were to skimp on any part of your build LucoTF to save money which part would it be?
Cheaper mobo
128gb ssd
cheaper case (but still good, comes with 4 fans + a fan controller)
cheaper PSU (450w is plenty for this rig)
not changing the KFA2 gtx 970!
