Hi guys,
So I've decided to build myself a little Windows 8.1 Pro based 2U rack mount server (I have a server closet in my home basement where the electrical, alarm, 24 port switch, router, cable, etc all goes into). I priced it all out on newegg.com as I am looking to purchase within the next couple of months, and this is what I have so far:
Intel Xeon E3-1220V3
SUPERMICRO MBD-X10SLM-F-O uATX Server Motherboard
Crucial 16GB (2 x 8GB) 240-Pin DDR3 SDRAM ECC Unbuffered DDR3 1600
2x Seagate NAS HDD ST2000VN000 2TB 64MB Cache SATA 6.0Gb/s (in RAID 5)
iStarUSA D-213-MATX Black Metal/ Aluminum 2U Rackmount microATX Server Chassis
Athena Power AP-P4ATX60FE 600W Single EPS12V V2.91
Now with all that i need cooling, but obviously I am not going to be pushing this to the limit, its a server, so it won't be overclocked or anythng and low power consumption is a priority as well as quiet. So I would really like it to be as quiet as possible. I think the PSU should be fairly quiet, the case has room for 2 fans, and I assume the CPU doesn't come with a cooler so I would need that. Whats the quietest setup I can do on this? I would just buy someones used 1U/2U server but those things sound like an F-16 at full bore.
This server will be primarily for backing up the household computers, also for streaming data, sharing files within the household, print server, and also to remote access files . I realize I can probably do this cheaper with a cheap NAS, but I like to build and tinker, so this is part functional, part science project.
