I am going to buy a new rig on Monday and I do not have the time or patience to build my own so I've decided on iBuyPower to build it. I am mostly going to play Skyrim, Deus EX HR, Crysis 2, and maybe some Witcher 2 enhanced.
My main requirements that I can NOT live without are that the "rig" must play (at least) the first 2 games listed above at 1920x1080 and be at 60fps constant with no dips in framerate at all.
My main components are listed below and my main questions are; What gpu do I need? And what is the minimum GPU required to meet the above requirements (so I can buy 1 step up)?
Processor 1 x Intel® Core™ i7-3770K Processor (4x 3.50GHz/8MB L3 Cache)-Intel Core i7-3770K
Motherboard 1 x ASRock Fatal1ty Z77 Performance
Memory 1 x 8 GB [4 GB X2] DDR3-1600 Memory Module-Corsair Vengeance
Video Card 1 x NVIDIA GeForce GTX 690 - 4GB-Single Card
Power Supply 1 x 1200 Watt Toughpower Grand-1200M
Processor Cooling 1 x Corsair Hydro Series H60 Liquid CPU Cooling System-ARC Dual Silent High Performance Fan Upgrade (Push-Pull Airflow)
Video Card Brand 1 x === High Performance === ASUS Brand Video Card
Primary Hard Drive 1 x 256GB OCZ Agility3 SSD
Data Hard Drive 1 x 120GB OCZ Agility 3 SSD
2nd Optical Drive 1 x 24X Sony Dual Format/Double Layer DVD±R/±RW + CD-R/RW Drive-Black
Operating System 1 x Microsoft Windows 7 Home Premium 64-Bit
Advanced Build Options 1 x Tuniq TX-2 High Performance Thermal Compound
^All adds up to about $2703 after the case and other unimportant stuff
My "budget" is The closer to $2000 the better but if necessary I can go above but $2750 MAX.
And yes I know I went a little overboard with cooling (No I don't plan to OC anything) if I went "Way off the deep end" on something please tell me.
I already have a 120Hz 1920x1080 Monitor, a keyboard, mouse, and some Logitech G35's.
Thanks in advance.
Thanks in advance.
Would a rig with an i7 x4 @ 4.1 GHz, and a GTX 690 work ok
