[SOLVED] Building a ryzen system
Aug 24, 2019
Hi. I want to build a workstation. I do numerical simulations on parallel.
Until now I have bought the cpu, and the motherboard. I would like to buy a gpu that supports cuda, in case I want to do some cuda programming.
This is what I have bought until now:
-CPU: Ryzen 7 1700x.
-MOBO: Motherboard Asrock Fatal1ty B450 Gaming K4 Amd Am4 Logg
I would like to buy a cheap graphics card that supports CUDA. I was thinking in the EVGA NVIDIA GeForce GTX 570. I think it supports CUDA. Would it be appropriate for the my mobo and cpu?
I also would like to ask which RAM should I buy for my system, which ssd, and which power supply and case would you recommend.
Thanks in advance.
PCPartPicker Part List
Type|Item|Price
CPU | AMD Ryzen 7 1700X 3.4 GHz 8-Core Processor | $0.00
Motherboard | ASRock Fatal1ty B450 GAMING K4 ATX AM4 Motherboard | $0.00
Memory | G.Skill Flare X 16 GB (2 x 8 GB) DDR4-3200 Memory | $72.99 @ Newegg
Storage | PNY CS900 240 GB 2.5" Solid State Drive | $29.99 @ Amazon
Video Card | Zotac GeForce GTX 1060 3GB 3 GB Mini Video Card | $169.99 @ Newegg
Case | Cooler Master MasterBox Lite 5 ATX Mid Tower Case | $39.99 @ Newegg
Power Supply | Corsair CX (2017) 650 W 80+ Bronze Certified ATX Power Supply | $69.88 @ OutletPC
Monitor | Asus VC279H 27.0" 1920x1080 60 Hz Monitor | $119.99 @ Newegg
| Prices include shipping, taxes, rebates, and discounts |
| Total (before mail-in rebates) | $542.83
| Mail-in rebates | -$40.00
| Total | $502.83
| Generated by PCPartPicker 2019-08-24 19:53 EDT-0400 |
Heres my take.
Or alternatively, you can get an even better USED gpu.
Type|Item|Price
Video Card | EVGA GeForce GTX 980 4 GB Superclocked ACX 2.0 Video Card | $140.00
| Total (before mail-in rebates) | $512.84
| Total | $472.84
| Generated by PCPartPicker 2019-08-24 19:59 EDT-0400 |
Used GTX 980 for $140. https://www.ebay.com/itm/NVIDIA-EVGA-GeForce-GTX-980-SC-GAMING-ACX-2-0-4GB-4G-256-bit-GDDR5-Video-Card/153614154152?epid=220561868&hash=item23c41df9a8:g:Rh8AAOSwAwJdXuDA&LH_BIN=1&LH_ItemCondition=3000|2500
980 performs better than a 1060 3gb and costs less.
Aug 24, 2019
Hi. Thank you both for your replies. I would like to invest as much as U$S500 to buy the gpu, the ram, the ssd, the case, the power supply and the display device. I was thinking in buying an old gpu, because I won't use the workstation to play videogames. I need a gpu and I would like one that supports CUDA. There are second hand gpus at a very low price on ebay, and that was the option I was looking at.
You think that the nvidia geforce gt 710 bould be a better option than the 570?
Type|Item|Price
| Total | $502.83
Heres my take.
Type|Item|Price
| Total | $472.84
