Hi Guys,
This is one of many questions I have at the moment regarding a new system that I want to build so if you could also assist me with those questions that would be brilliant thanks!
I'm hoping to build a small form factor Micro-ATX or Mini-ITX system for university in September and I'm unsure of what case to use. I want something that I can place on a desk that won't take up too much room. I will be using a dedicated GPU (something like the GTX 970) but not necessarily a mini-itx version. The case must also be able to hold an SSD and a HDD. Optical drive slot isn't necessary as I can always use an external one but I won't consider it a negative if the case does have one. Cooling is also a factor and I'd like to make sure the components are comfortably cooled, whether that be through an air or a water cooler (I'm open to suggestions on what setup would be best with a particular case), whilst not being too loud.
I've listed some cases and some builds which I like the look of.
Silverstone SG09 or SG10
I was really impressed with this build from NCIX, although I only plan on using a single GPU: https://www.youtube.com/watch?v=OSOxvwbke9w
Rosewill U3
I understand that this name varies from region to region but I've seen some fairly impressive builds with this case. My only uncertainty is cooling and its storage facilities.
http://uk.pcpartpicker.com/b/zbYrxr
http://uk.pcpartpicker.com/b/93JV3C
Another Linus SFF build which I like the look of, although people have said his temperatures (mentions them near the end in a conclusion) are very high which makes me feel uncomfortable. The noise level is impressive though.
https://www.youtube.com/watch?v=aGIb0tws_e4
The Prodigy is simply too big in my opinion so I'd like something smaller. The Corsair 250D and Node 304 are also contenders for mini-itx and the Corsair air 240 for Micro-atx.
Any suggestions would be much appreciated. Thanks.
Rosewill U3
