Hello People,
I want to build a "small" watertank inside an old Dark Base Pro 900 (this may sound mad but the idea got stuck in my head and i would like to give it a shot).
My Plan is to build a small Watercontainer out of glas that covers up half the Cases width (So basically the side window would be covered). I need it to have enough clearance to fit a very basic system behind it and use it as a Aquarium with a build in Homeserver.
Unfortunately i don't how one would even start such a project, so i came here to get an insight from fellow builders.
Things i have figured out so far that would have been an issue-
-Maintaining the Hardware while the Tank+Water is installed
-PCIe Clearance (i dont need any so that kinda solved itself)
I have never worked with Glas before so if you have experience with building a Aquarium yourself let me know.
Ideas and concerns are very welcome.
Thank you all in advance <3
