Building a WoW machine for $500.
brandon1212
Hey. Before I get started I want to thank you for your interest by opening this. Also I apologize as I'm comparatively computer illiterate. I'm building a gaming machine which at most can cost me $500. My five year old computer's motherboard died and the system is so old that I cant use hardly anything from it. I know the ram and video card slotting has changed so they will be pretty useless. I'm thinking I might be able to use the hard drive but I know its not SATA (whatever that means).
So heres my first question is there any way to move windows from one hard drive to another? I lost installation disks and key over the years and really am strapped for cash. So I might get stuck using my old hard drive if thats possible.
Also my old sound card was an audigy 2. Has slotting changed over the years and will i be able to use it?
So by looking at reviews I've kinda built this system on newegg. If you see anything that might need changing or where i could save a bit a money without losing preformance or switch a couple parts up and gain performance i would be greatful. Thanks again!
Seagate Barracuda 7200.12 ST3500418AS 500GB 7200 RPM SATA 3.0Gb/s Hard Drive
Seagate Barracuda 7200.12 500GB 3.5" SATA 3.0Gb/s Hard Drive
Item #:N82E16822148395
Return Policy: 30 Day Return Policy
-$5.00 Instant
$64.99
$59.99
BIOSTAR TFORCE TA790GX 128M AM2+/AM2 AMD 790GX HDMI ATX AMD Motherboard
BIOSTAR TFORCE TA790GX 128M ATX AMD Motherboard
Item #: N82E16813138130
AMD Athlon 64 X2 5400 Brisbane 2.8GHz Socket AM2 65W Dual-Core black edition Processor Model ADO5400DSWOF
AMD Athlon 64 X2 5400 2.8GHz Socket AM2 65W Dual-Core black edition Processor
Item #: N82E16819103289
Return Policy: Processors (CPUs) Return Policy
-$10.00 Instant
-$20.00 Combo
$10.00 Mail-in Rebate
$172.98
$142.98
OCZ Reaper 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1150 (PC2 9200) Desktop Memory Model OCZ2RPR11504GK
OCZ Reaper 4GB (2 x 2GB) 240-Pin DDR2 1150 (PC2 9200) Desktop Memory
Item #: N82E16820227406
Return Policy: Limited Non-Refundable 30-Day Return Policy
MSI N9800GT-T2D512-OC V2 GeForce 9800 GT 512MB 256-bit GDDR3 PCI Express 2.0 x16 HDCP Ready SLI Supported Video Card
MSI GeForce 9800 GT N9800GT-T2D512-OC V2 Video Card
Item #: N82E16814127406
-$25.00 Instant
-$20.00 Combo
$15.00 Mail-in Rebate
$20.00 Mail-in Rebate
$205.98
$160.98
RAIDMAX SMILODON ATX-612WB Black 1.0mm SECC Steel ATX Mid Tower Foldout MB Computer Case
RAIDMAX SMILODON ATX-612WB Black Foldout MB Computer Case With Side Panel Window
Item #: N82E16811156063
Return Policy: Standard Return Policy
RAIDMAX RX-700SS 700W ATX12V V2.2/ EPS12V SLI Ready CrossFire Ready Modular Modular LED Power Supply
RAIDMAX RX-700SS 700W Modular LED Power Supply
Item #: N82E16817152030
-$40.00 Instant
-$30.00 Combo
$199.98
$129.98
Grand Total: $493.93
This cpu (E5200) will OC nicely to 3.3GHz @ 1066 fsb (12.5 x 266). That case is vented and set up for 3 x 120mm case fans. It comes with two of them, and I added another one in this build.
http://www.newegg.com/Product/Product.aspx...N82E16811119106 <=== Some better pics of that case.
http://cmstore.coolermaster-usa.com/produc...?products_id=84 $22.99
Centurion 534 Black Mid Tower, W/O window, W/O PSU - Refurbished
http://www.newegg.com/Product/Product.aspx...N82E16835150070[/url] $4.99
MASSCOOL FD12025S1L3/4 120mm Case Fan - Retail
http://www.newegg.com/Product/Product.aspx...N82E16817341021 $59.99
OCZ Fatal1ty OCZ400FTY 400W ATX12V / EPS12V Active PFC Power Supply - Retail
http://www.newegg.com/Product/Product.aspx...N82E16813128380 $84.99
GIGABYTE GA-EP43-UD3L LGA 775 Intel P43 ATX Intel Motherboard - Retail
http://www.ewiz.com/detail.php?name=E5200 $64.99 Free Ground Shipping
Intel E5200 Dual-Core 2.5GHz 775 800MHz 2MB CPU OEM
http://www.digiconcepts.com/arcticcooling_cooling_06.htm $22.95
Arctic Cooling Freezer 7 Pro Intel Socket 775 CPU Fan
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130468 $134.99
EVGA 512-P3-1150-TR GeForce GTS 250 512MB 256-bit GDDR3 PCI Express 2.0 x16 HDCP Ready SLI Supported Video Card - Retail
http://www.newegg.com/Product/Product.aspx...N82E16820231122 $39.99 Free Shipping*
G.SKILL 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory - Retail
http://www.newegg.com/Product/Product.aspx...N82E16822136010 $39.99 Free Shipping*
Western Digital Caviar RE WD2500YD 250GB 7200 RPM 16MB Cache SATA 3.0Gb/s Hard Drive - OEM
http://www.newegg.com/Product/Product.aspx...N82E16827106287 $22.99
LITE-ON Black 22X DVD+R 8X DVD+RW 8X DVD+R DL 22X DVD-R 6X DVD-RW 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM SATA 22X DVD Burner - OEM
Total: $496.12 *(not including shipping and rebates)
Here's an AMD build, includes operating system and hard drive.
CPU/ power supply combo - $100 with rebate. AMD 64X2 7750 Kuma and a 450w Corsair PSU.
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.174725
Motherboard - Gigabyte MA770UD-3 $65 after rebate
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128376
RAM - 2x2 GB DDR2 800 1.8v $30 after rebate
http://www.newegg.com/Product/Product.aspx?Item=N82E16820146692
Case - Rosewill $28 with free shipping, single 120mm fan
http://www.newegg.com/Product/Product.aspx?Item=N82E16811147109
Graphic card - Sapphire HD4830 $75 after rebate
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102822
HD - WD 320GB SE16 SATA $55
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136074
Burner - Samsung SATA $23
http://www.newegg.com/Product/Product.aspx?Item=N82E16827151171
OS - Vista 64 $100
http://www.newegg.com/Product/Product.aspx?Item=N82E16832116488
$521 before rebates, $15.30 shipping (to me), $45 in eventual rebates.
Will run WoW at 50-60 fps everywhere but Dalaran and Wintergrasp, including 25 man Naxx, EOE, Sarth. Nothing runs 50fps+ in WG and Dal since it's a server isssue.
