building an itx pc
Jan 27, 2019
22
I need help deciding how to build a good itx gaming pc, I have an cool master mid tower that I would like to build possibly an Intel cpu 8th gen.
Motherboard, gpu, ram, ect.
the case I have only supports itx and mini atx motherboards but it's full size its weird but I've heard good things about 800-900$ mini builds
Here is my mini-itx build:
https://i.imgur.com/VSfUowt.jpg
And with all the case panel off
https://i.imgur.com/xrZL6fr.jpg
it's because of the motherboard I have in it got me confused cause it's a micro atx
Find a link to your exact case and post it here. You clearly don't have any idea what you're doing as you keep mixing atx and itx.
If you're having that much confusion over what sized motherboard it concerns me about the rest of your build as well. Please list your budget, any parts you have already purchased, and do you need a monitor/peripherals in that budget
