Building Computer for Friend
xELITEx
37
Building computer for a friend will this work?
AMD Phenom II x4 965 Black Edition 3.4 GHz
Gigabyte GA-MA78LMT-S2
Radeon HD 6570 1GB or Radeon HD 4670 512mb
Kingston DDR3 RAM 8GB
Seagate Barracuda 7200 RPM 1TB
460W Cooler Master Elite
HP 24X CD/DVD Burner
Rosewill Challenger Case
W7x64
*Going for a Cheap Build*
Actually,tested on Borderlands 2,and Skyrim and have no idea what his resolution is personaly i was gonna get the 6670 2gb and he has a budget of $500 which the build is already passing by a bit.
Like tiny voices said, the Coolermaster PSU is near-junk. Depending on the games and resolution, you might find a GDDR5 version of the HD6670 acceptable, but I'd strongly suggest something better. A HD7770 is only $115 now. In between those two lies the HD7750.
Also, I know you want cheap, but I'd also suggest a better mobo, like http://www.newegg.com/Product/Product.aspx?Item=N82E16813157319 in order to get USB3.0 and SATA 6Gb/s. There's a $10 off promo code on it right now too.
