Building desktop- Case and MB question
hpfreak
935
43
I am wondering if the motherboard will fit in the case... I'm sorry if it is a stupid question, but I don't want to order a part that turns out to be the wrong size ...
Here are the links to the Newegg pages:
Case: http://www.newegg.com/Product/Product.aspx?Item=N82E16811147153
Motherboard: http://www.newegg.com/Product/Product.aspx?Item=N82E16813131767
Currently, I've sized up with this build, Most of it came from another thread that I asked for help on.
CPU: http://www.newegg.com/Product/Product.aspx?Item=N82E16819103808
GPU: http://www.newegg.com/Product/Product.aspx?Item=N82E16814121442
RAM: http://www.newegg.com/Product/Product.aspx?Item=N82E16820231277
PSU: http://www.newegg.com/Product/Product.aspx?Item=N82E16817207013
DVD: http://www.newegg.com/Product/Product.aspx?Item=N82E16827135204
CPU COOLER: http://www.newegg.com/Product/Product.aspx?Item=N82E16835103064
Thanks guys,
Also, if you can check to see if the PSU is good enough, I think it is... But then again, I have no backup proof :)
Really, I'm mostly worried about the case and motherboard, if there has to be a change, I'd rather get a different case then switch other components. Keep in mind, that this is a tight budget computer, current spec'd, tax and shipping, would total at 538 dollars, would only go a few dollars higher (like 3 :) )
Thanks,
P.S. I already have a Windows 7 License, and a 3.5" HDD, So, I don't need to worry about those factors.
I have a Windows 7 Home Premium 64x License, and a Seagate Barracuda 500 GB 7,200 RPM 3.5" HDD.
david2655
23
plz label the links!!! very few people are going to bother clicking each one seperately
dangerboyjtf2
45
There are different form factors for each case/mobo. ATX/MicroATX/MiniATX, and I think there are a couple others.
In the title of the case it says "ATX" so you know it'll fit an ATX motherboard. If you go to "details" and check the "Form Factor" you'll see it fits both "ATX" and "Micro ATX" motherboards.
And since the motherboard's title says "ATX" (which you can confirm by going to its details and checking), you know it is ATX as well.
Hence they'll fit! (as Boiler already said, I was just giving an explantion so he can find out in the future if need be).
Similar threads
