Building first gaming build, Are these parts compatible with each other?
May 9, 2017
72
Motherboard: ASUS ROG STRIX Z270F GAMING LGA1151 DDR4 DP HDMI DVI M.2 ATX Motherboard with USB 3.1 by Asus
Display:
Acer GN246HL Bbid 24-Inch 3D Gaming Display (144Hz Refresh Rate) by Acer
Mouse:
Razer DeathAdder Elite - Multi-Color Ergonomic Gaming Mouse - World's Most Precise Sensor - Comfortable Grip - The eSports Gaming Mouse by Razer
Keyboard :
Logitech G213 Prodigy Gaming Keyboard with 16.8 Million Lighting Colors (920-008083) by Logitech
RAM: GSKILL Ripjaws X F3-17000CL11D-8GBXL 8GB (2x4GB) DDR3-2133Mhz Desktop RAM Memory by G.Skill
Fans:
Cougar Vortex HDB 120 Cooling CF-V12H, Orange by Cougar
Case:
Cooler Master HAF X - Full Tower Computer Case with High Airflow Windowed Side Panel and USB 3.0 by Cooler Master
Graphics Card:
EVGA GeForce GTX 1050 Ti SSC GAMING ACX 3.0, 4GB GDDR5, DX12 OSD Support (PXOC) Graphics Card 04G-P4-6255-KR by EVGA
Microphone:
Razer Seiren Elite USB Digital Microphone - Record with Professional-Grade Studio Sound by Razer
Power supply: Supernova 750 G2 750watt gold power supply
Processor:
Intel Core i7-2600K Quad-Core Processor 3.4 Ghz 8 MB Cache LGA 1155 - BX80623I72600K by Intel
u need a intel 6th or 7th gen prcessor to match that mobo.
u dont need 750w. a 550w is more than enough even considering future gpu upgrade.
ur peripherals r overpriced. look for a loitech g502 mouse and logitech g430 headset which comes with a mic.
consider a gtx1060 6gb or rx580 4gb/8gb for gpu.
or, tell us ur budget n location. we can draft u a build.
May 9, 2017
72
May 9, 2017
72
I don't think I can do that because the GPU, mobo and a bunch of other stuff are not listed on the website. I also want to know if my build will be able to record gameplay with very minimal lag? That is why I want the NVIDIA GPU.
CRO5513Y
Expert
Ambassador
Above is the reason most the parts aren't on there, they are too old. If you are buying these new you should be going for a newer generation like Intel 6th/7th Gen or AMD Ryzen. As for the GPU i'm not sure what you mean by record gameplay with minimal lag i assume you are referring to Nvidia ShadowPlay, is so Radeon cards have ReLive now which is just as good. See more details on it here > https://www.techpowerup.com/reviews/AMD/Radeon_Crimson_ReLive_Drivers/3.html.
Like Lucky_SLS mentioned if you can let us know your location/budget we can help put together a list similar to what you have but with newer parts and you can see what you think. :)
ur choice of model is wrong, not the processor. or i should say, yes, i7 is a good choice. but only 6xxx or 7xxx series of i5, i7 will match that mobo.
if u already have that PSU, no issues there. thats a very good model.
ur choice of gpu is a weak one. to max out 1080p u need a gtx 1060 or rx480/580. those crds will give u 60+ fps for sure. if u plan to keep ur gpu for 3-4 years, get a gtx1070 or its equivalent from Vega.
y vega? free sync monitors r cheaper than g sync ones ;)
May 9, 2017
72
[/quotemsg]
Like Lucky_SLS mentioned if you can let us know your location/budget we can help put together a list similar to what you have but with newer parts and you can see what you think. :)[/quotemsg]
Alright, so I live in the United States, and I have a $1,500 budget for computer parts.
CPU: Intel - Core i7-7700K 4.2GHz Quad-Core Processor ($329.89 @ OutletPC)
CPU Cooler: Scythe - Mugen 5 51.2 CFM CPU Cooler ($46.99 @ Amazon)
Motherboard: ASRock - Z270 Killer SLI/ac ATX LGA1151 Motherboard ($122.98 @ Newegg)
Memory: G.Skill - Ripjaws V Series 16GB (2 x 8GB) DDR4-3200 Memory ($109.99 @ Newegg)
Storage: SK hynix - SL308 250GB 2.5" Solid State Drive ($84.88 @ OutletPC)
Storage: Seagate - BarraCuda 1TB 3.5" 7200RPM Internal Hard Drive ($46.49 @ OutletPC)
Video Card: Asus - Radeon RX 580 4GB Dual Video Card ($209.99 @ B&H)
Case: Phanteks - ECLIPSE P400 ATX Mid Tower Case ($65.99 @ NCIX US)
Power Supply: Corsair - CXM 550W 80+ Bronze Certified Semi-Modular ATX Power Supply ($37.99 @ Newegg)
Operating System: Microsoft - Windows 10 Home OEM 64-bit ($87.89 @ OutletPC)
Monitor: AOC - G2460PF 24.0" 1920x1080 144Hz Monitor ($209.95 @ Amazon)
Keyboard: Thermaltake - POSEIDON Z Wired Gaming Keyboard ($65.95 @ Jet)
Mouse: Logitech - G302 Daedalus Prime Moba Wired Optical Mouse ($28.35 @ Amazon)
Headphones: Logitech - G430 7.1 Channel Headset ($38.99 @ Amazon)
Total: $1486.32
Generated by PCPartPicker 2017-05-20 09:55 EDT-0400
72
Ok, so what I want, is something that will be quiet, especially during recordings. I also want a powerful computer, that can run very good framerate WHILE I am recording. (That is pretty much all I want for my pc, but if you could include the monitor price within the 1500 dollar range the would be amazing)
May 9, 2017
72
Thank you for the build, I looked through it, and I want to know how much storage do I really need for gaming? I came up with my own build and I chose a 2TB storage.
May 9, 2017
72
Ok, so I build a PC of my own on PCpart picker, and I also raised by budget a little bit. How is this build?
CPU- Intel - Core i7-7700K 4.2GHz Quad-Core Processor
$329.89
CPU Cooler - be quiet! - Dark Rock 3 67.8 CFM Fluid Dynamic Bearing CPU Cooler
$65.49
Motherboard - MSI - Z270-A PRO ATX LGA1151 Motherboard
$109.49
Memory: Crucial - Ballistix Sport LT 8GB (2 x 4GB) DDR4-2400 Memory
$59.99
Storage: Seagate - Barracuda 2TB 3.5" 7200RPM Internal Hard Drive
$69.89
Video Card: MSI - GeForce GTX 1060 6GB 6GB GAMING X Video Card
$259.99
Case: NZXT - S340 (Black/Red) ATX Mid Tower Case
$61.99
Power Supply: EVGA - SuperNOVA G2 750W 80+ Gold Certified Fully-Modular ATX Power Supply
$99.99 (Free because I already have this)
OS - Microsoft - Windows 10 Home OEM 64-bit
$87.89
Wireless Network Adapter - Belkin - F7D2102 USB 2.0 802.11b/g/n Wi-Fi Adapter
$17.63 (Do I need this part?)
Monitor - Acer - GN246HL 24.0" 1920x1080 144Hz Monitor
$182.99
Keyboard - Logitech - G213 PRODIGY Wired Gaming Keyboard
$59.99 (My dad has this one, is it amazing)
Mouse - Razer - DeathAdder Chroma Wired Optical Mouse
$42.92
Microphone - Razer Seiren Elite USB Digital Microphone - Record with Professional-Grade Studio Sound
$178.87
Total: $1627.01
You could deduct the price of the power supply because I already have that and it would be 1527.01
Would this be powerful but quiet enough to fit my needs?
Go for my choice of cooler/mobo/ram. better perf n features.
what abt the ssd? i highly recommend u get one.
if u want a quiet case, take a look at corsair 500R. but if u like s340, go for it. the p400 case got more cooling solutions than s340.
the rx580 4gb/8gb is enough to max out 1080p. its better than gtx 1060 since free sync monitor is cheaper. so go for my choice of monitor obviously.
the keyboard i mentioned is a mechanical one. the one u suggested is a membrane one. if u r ok, no issues.
i wouldnt trust razer mouses since it got so many software implimentation glitches. perf is good. but features may not work properly. try the g502 mouse if u have the cash. worth it.
that g430 has inbuilt mic and has 7.1 sound channel. no need to spend extra on the mic.
May 9, 2017
72
Ok, so this is the updated build,
CPU - Intel - Core i7-7700K 4.2GHz Quad-Core Processor
CPU Cooler - Scythe - Mugen 5 51.2 CFM CPU Cooler
Mobo- ASRock - Z270 Killer SLI/ac ATX LGA1151 Motherboard
Memory - Crucial - Ballistix Sport LT 8GB (2 x 4GB) DDR4-2400 Memory
Storage - Seagate - Barracuda 2TB 3.5" 7200RPM Internal Hard Drive
GPU - Gigabyte - Radeon RX 580 4GB Gaming 4G Video Card
Case - Phanteks - ECLIPSE P400 ATX Mid Tower Case
Power Supply - EVGA - SuperNOVA G2 750W 80+ Gold Certified Fully-Modular ATX Power Supply
Wireless Network Adapter - Belkin - F7D2102 USB 2.0 802.11b/g/n Wi-Fi Adapter (Is this part still needed?)
Monitor - AOC - G2460PF 24.0" 1920x1080 144Hz Monitor
Mouse - Razer - DeathAdder Chroma Wired Optical Mouse (I really like this mouse, it works really well for my games)
Microphone - Razer Seiren Elite USB Digital Microphone - Record with Professional-Grade Studio Sound ( I need this for when I record my games, and I need very good audio quality)
SSD - SK hynix - SL308 250GB 2.5" Solid State Drive (How would an SSD help me exactly? Sorry, but I am new to computer parts, I have been working with sowftware most of my life :))
u dont have the high speed ram[memory]. ur selection is listed at 2400mhz, mine is at 3200mhz. simply put, faster the better.
install windows and ur games in SSD. the SSD makes ur loading time very short. like booting times in seconds. no more loading circles going round and round ;)
u dont need the wifi card. forgot to say that. mobo comes with one.
May 9, 2017
72
Ok, thank you so much for your time and help! I updated my ram to yours, got rid of the wifi card, and so am I all set to order the parts?
g-unit1111
Why do you need such an expensive microphone? I'd say lose the expensive peripherals (which you can always buy later) and invest that back into your GPU. Spending that kind of money on a system you should have at least a 1070 or 1080.
May 9, 2017
72
Well, I mean the GPU looks pretty good to me, (not that I know too much about it ;)) but I need the microphoneto record quality audio, and the keyboard and mouse look neat as well, are you suggesting that I go with the cross fire for the GPU?
May 9, 2017
72
Yea, but is outlet PC a trustworthy site? I have never heard of it before as I have been using Amazon for everything. I always thought they had everything until now :)
