Hi, I'm currently building my first gaming PC and I'm wondering between 2 Graphic cards.
EVGA 02G-P4-2678-KR GeForce GTX 670 FTW 2GB 256-bit GDDR5 PCI Express 3.0 x16 HDCP Ready SLI Support Video Card (400$)
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130787
And
MSI N670 PE 2GD5/OC GeForce GTX 670 2GB 256-bit GDDR5 PCI Express 3.0 x16 HDCP Ready SLI Support Video Card (390$)
http://www.newegg.com/Product/Product.aspx?Item=N82E16814127685
I'm tempting to go with the first one. but some people is telling me the second one is better(better cooling system). Witch one do you guys thing I should go for? Witch one would be the best? I want to play BF3 and other big games in max, or at least close to max settings.
These are my other parts I'm buying if it can help in anyway way to decide the best GPU:
CPU:
Intel Core i5-3570K Ivy Bridge 3.4GHz (3.8GHz Turbo) LGA 1155 77W Quad-Core Desktop Processor Intel HD Graphics 4000 BX80637I53570K
http://www.newegg.com/Product/Prod [...] 6819116504 (214$)
CPU Cooler:
COOLER MASTER Hyper 212 EVO RR-212E-20PK-R2 Continuous Direct Contact 120mm Sleeve CPU Cooler Compatible with latest Intel 2011/1366/1155 and AMD FM1/FM2/AM3+
http://www.newegg.ca/Product/Produ [...] 6835103099 (36$)
Motherboard:
GIGABYTE GA-Z77X-UD5H LGA 1155 Intel Z77 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
http://www.newegg.com/Product/Prod [...] 6813128545 (190$)
Memory:
Crucial Ballistix Sport 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Low Profile Desktop Memory Model BLS2K4G3D1609ES2LX0
http://www.newegg.com/Product/Prod [...] 6820148662 (40$)
Harddrive:
SAMSUNG Spinpoint F3 ST1000DM005/HD103SJ 1TB 7200 RPM 32MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
http://www.newegg.com/Product/Prod [...] 6822152185 (85$)
Harddrive:
Crucial M4 CT128M4SSD2 2.5" 128GB SATA III MLC Internal Solid State Drive (SSD)
http://www.newegg.com/Product/Prod [...] 6820148442 (110$)
Power Supply:
PC Power and Cooling Silencer Mk II 750W High Performance 80PLUS Silver SLI CrossFire ready Power Supply
http://www.newegg.com/Product/Prod [...] 6817703027 (110$)
Optical Drive:
LITE-ON DVD Burner - Bulk 24X DVD+R 8X DVD+RW 12X DVD+R DL 24X DVD-R 6X DVD-RW 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM Black SATA Model iHAS124-04 - OEM
http://www.newegg.com/Product/Prod [...] 6827106289 (22$)
Case:
NZXT Phantom PHAN-001WT White Steel / Plastic Enthusiast ATX Full Tower Computer Case
http://www.newegg.com/Product/Prod [...] 6811146067 (120$)
And
CPU:
CPU Cooler:
Motherboard:
Memory:
Harddrive:
Harddrive:
Power Supply:
Optical Drive:
Case:
