Building first system and have an SSD question.
tdonn16
64
4
18,535
I am building my first gaming PC and I want to know if i should include a SSD, or if I can just add one later. Any help/opinions are appreciated. here is my build, my budget is under 800, but i just sold a ton of games at gamestop so i am a little flexible. Thank You!
PCPartPicker part list: https://pcpartpicker.com/list/PTYWRG
Price breakdown by merchant: https://pcpartpicker.com/list/PTYWRG/by_merchant/
CPU: AMD - Ryzen 5 1500X 3.5GHz Quad-Core Processor ($189.00 @ Amazon)
Motherboard: ASRock - AB350M Pro4 Micro ATX AM4 Motherboard ($77.98 @ Newegg)
Memory: Corsair - Vengeance LPX 8GB (2 x 4GB) DDR4-3000 Memory ($79.99 @ Amazon)
Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($47.99 @ Amazon)
Video Card: Gigabyte - GeForce GTX 1060 6GB 6GB WINDFORCE OC 6G Video Card ($280.00)
Case: Cooler Master - MasterBox Lite 5 ATX Mid Tower Case ($49.99 @ Amazon)
Power Supply: EVGA - BQ 500W 80+ Bronze Certified Semi-Modular ATX Power Supply ($54.99 @ Amazon)
Total: $779.94
Generated by PCPartPicker 2017-07-09 15:50 EDT-0400
1. The difference between the $57 Kingston and the $99 Crucial is ~$40. Within your budget.
2. You can install and run Windows 10, unactivated, until you go buy a license key.
It is not "free", and it has a few restrictions. But it will work.
is it hard to transfer the OS, a friend told me it is a pain. i could probably squeeze this SSD into my budget if it is a good one (i just got $160 dollars of flexibility but i also still need to get windows 10)
PCPartPicker part list: https://pcpartpicker.com/list/bY6qnn
Price breakdown by merchant: https://pcpartpicker.com/list/bY6qnn/by_merchant/
Storage: Kingston - A400 120GB 2.5" Solid State Drive ($56.98 @ Newegg)
Total: $836.92
Generated by PCPartPicker 2017-07-09 16:05 EDT-0400
ok, thank you!
It can be hard, after you've used the system for a while, and your C drive contents is larger than the new SSD.
For instance...if you eventually get a 250GB SSD, you need the total consumed space on the original drive to be below 200GB for a successful clone operation.
Otherwise, you're doing a whole new OS (and everything else) reinstall.
With your current single drive of a 1TB, I give that no more than 3 weeks before you are over that cloneable space...:lol:
OS, applications, a couple of large Steam games.....oops...too much.
actually i have like 60 dollars of free space because i also have to get windows 10. (sorry should have mentioned this earlier)
Ok, Thank You!
