building gaming pc. help?
Yup really good parts, but you may want to change the PSU the something by EVGA as they have better components inside of the PSUs.
EVGA: http://pcpartpicker.com/part/evga-power-supply-110b10750vr
If you wanted to you could go with this model:
http://pcpartpicker.com/part/evga-power-supply-120g10750xr
Its better as its full modular and gold rated, so more efficient.
Hope this helps :)
The_Freeman
THANKS. also do i need a cpu cooler . or thermal compund .
It does come with a stock cooler which will be fine and comes with pre applied thermal paste but if you do want to Overclock then it is recommended that you get a CPU cooler. Some come with thermal compound but its better to buy is separately as its usually better.
A good CPU cooler is the 212 EVO from cooler master, and arctic silver mk 4 is very good thermal paste
Hope this helps :)
The_Freeman
