Building Gaming PC Please HELP!
AbsoluteBuilder
Commendable
Feb 28, 2016
13
Hello hi I am building a Gaming PC for $400 please help me look at the parts/specifications below and tell me if there incompatible or compatible, For the processor I went with the AMD A10 7870k Quad Core can I game on it without using a GPU/VC? if I need anything else added I can go as high as $450 for the price. Also I could have gone with an I3 but I didn't really want that processor. Please take a look at the specs and reply back.
(SPECIFICATIONS)
http://pcpartpicker.com/p/cg9ysY
CPU: AMD A10-7870K 3.9GHz Quad-Core Processor (Goldavari)
Mobo: ASRock FM2A68M-DG3+ Micro ATX FM2+ Motherboard
Memory: Crucial 8GB (1 x 8GB) DDR3-1600 Memory
HDD: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive
GPU: XFX Radeon R7 360 2GB Core Edition Video Card
Case/PSU: Logisys CS305BK ATX Mid Tower Case w/480W Power Supply
Sorry if you cant understand my writing please I need as much as help I can get from here.
Thanks in advance
I think this would be far better for your budget. You can upgrade the CPU to an i5 / i7 later on and keep this system running for years with performance better than anything amd currently has to offer.
CPU: Intel Core i3-6100 3.7GHz Dual-Core Processor ($112.99 @ SuperBiiz)
Motherboard: Asus H110M-A Micro ATX LGA1151 Motherboard ($58.99 @ SuperBiiz)
Memory: G.Skill Ripjaws 4 series 8GB (2 x 4GB) DDR4-2133 Memory ($37.99 @ Newegg)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive ($45.89 @ OutletPC)
Video Card: EVGA GeForce GTX 750 Ti 2GB Video Card ($118.99 @ SuperBiiz)...
Case: Silverstone PS08B (Black) MicroATX Mid Tower Case ($34.99 @ Amazon)
Power Supply: Antec 450W ATX Power Supply ($32.79 @ Directron)
Total: $450.83 before rebates
Total: $420.83 after rebates
Generated by PCPartPicker 2016-03-19 21:43 EDT-0400
I wouldn't go for that gpu/cpu combo.I would either pare that cpu with a r7 250 for dualgraphics or get the Athlon 860K with a better gpu.The last option would be the best one.
Two builds that give both options,the imo best one first,
CPU: AMD Athlon X4 860K 3.7GHz Quad-Core Processor ($69.99 @ Newegg)
Motherboard: ASRock FM2A88X PRO3+ ATX FM2+ Motherboard ($57.55 @ Newegg)
Memory: G.Skill Ares Series 8GB (2 x 4GB) DDR3-2400 Memory ($37.99 @ Newegg)
Video Card: XFX Radeon R7 370 2GB Double Dissipation Video Card ($114.99 @ Newegg)
Case: Enermax ECA3212-BL ATX Mid Tower Case ($24.99 @ Newegg)
Power Supply: EVGA 750W 80+ Bronze Certified Semi-Modular ATX Power Supply ($48.99 @ NCIX US)
Total: $400.39
Generated by PCPartPicker 2016-03-19 22:01 EDT-0400
the dualgraphics build now,
CPU: AMD A10-7870K 3.9GHz Quad-Core Processor ($126.66 @ Amazon)
Video Card: Asus Radeon R7 250 1GB Video Card ($64.99 @ Micro Center)
Power Supply: Deepcool 550W 80+ Gold Certified ATX Power Supply ($49.99 @ Newegg)
Total: $408.06
Generated by PCPartPicker 2016-03-20 08:25 EDT-0400
Guys I havent bought the items yet. Also I didn't mean to say I didn't want to go with an I3, its just that its a Dual Core Processor.
And I heard that you can't play games on a Dual Core you need Quad Core. Ok so Ignore that but what should I get guys what do you recommend me to get please give me a list
Should I really go with a GTX Geforce 750Ti? I thought its not good for gaming
Nothing inherently wrong with the builds above , this below is based on trying to take rebates out of the equation.
Motherboard: Asus A68HM-Plus Micro ATX FM2+ Motherboard ($52.99 @ SuperBiiz)
Memory: Mushkin Blackline 8GB (2 x 4GB) DDR3-2133 Memory ($36.99 @ Newegg)
Video Card: Asus Radeon R7 370 2GB Video Card ($99.99 @ Micro Center)
Case: Cooler Master N200 MicroATX Mid Tower Case ($46.99 @ SuperBiiz)
Power Supply: EVGA 500W 80+ Bronze Certified ATX Power Supply ($34.99 @ NCIX US)
Total: $387.83
Generated by PCPartPicker 2016-03-20 07:35 EDT-0400
It can.The i3 6100 is a dualcore cpu,but has hyper threading so can work with four threads,not the same as four real cores,but still capable and very fast.The amd's can suffer mostly at the lower fps when gaming,for that is the intel often better.
About an AMD motherboard,i would pick the one i chose,i think it has some overclock capapbilities,i chose it for that reason,you could later add an aftermarket cooler and try that.
I see remarks about rebates.Are they an option for you? Partslists vary day by day,prices drop and rise on most parts,like gpu and psu the most.Look at these as guidance.
