Building help...quick!
b10n
45
APPROXIMATE PURCHASE DATE: couple days
BUDGET RANGE: 500-750
SYSTEM USAGE FROM MOST TO LEAST IMPORTANT: internet, movies, music, cds, buring cds
PARTS NOT REQUIRED: monitor
PREFERRED WEBSITE(S) FOR PARTS: newegg
PARTS PREFERENCES: intel, evga
OVERCLOCKING: no
SLI OR CROSSFIRE: no
MONITOR RESOLUTION: 720p
ADDITIONAL COMMENTS: i just need a build quick to present to my parents so i can get it...just for multitasking and mabey making beats...studio work.... make it as cheap AS POSSIBLE. Make it faster than this pc http://wize.com/pc-desktops/p164205-hp-hp-pavilion-media-center-tv-m7680n
thank you
You are limiting yourself by asking for Intel in this case. At this budget and usage an AMD X3 720 makes the most sense.
X3 and 760G motherboard combo
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.191016
Antec case and PSU combo
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.193754
G.Skill RAM
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231226
WD 320GB HD
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136074
DVD Burner
http://www.newegg.com/Product/Product.aspx?Item=N82E16827136152
You can add a discrete video card if you like, but the onboard is enough for non-Blu-ray titles, and might even run Blu-ray well.
Upgradeable for the future?
Then you want an AMD build or an i7/X58 build. LGA 775 has been a great socket, but it's done. The new Intel mainstream boards will be out later this year.
Also, DDR2 is going up in price while DDR3 is coming down, so any RAM upgrades to a DDR2 board in the future may be expensive.
There is nothing wrong with your build in general, although the PSU is overkill. The case is OK as long as you aren't overclocking.
then wat would be a reasonable power supply...modular
A decent modular power supply is expensive. I'm not sure why you need one for a case with no window that has no airflow to block.
This BFG is enough and is considered a bit higher quality than that OCZ.
http://www.newegg.com/Product/Product.aspx?Item=N82E16817702014&Tpk=BFG%20LS-450
This Corsair would be ideal:
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139003&Tpk=450VX
However, if you MUST have modular:
http://www.newegg.com/Product/Product.aspx?Item=N82E16817151057
Top quality, 5-year warranty.
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115206 Dual core 2.8 Ghz $119.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16813188043 Stable 780i motherboard with onboard sound. decent upgradability. $165
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139005 650Watt powersupply with a 52Amp 12volt rail $94.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16811103010 Convenient tower full size , cold quiet. $100
http://www.newegg.com/Product/Product.aspx?Item=N82E16820146764 2GB low latency RAM Stable , low voltage. $32.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148335 640GB harddrive SATA2 7200rpm $65
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130394 DX10 video card can play most games at 1280x720 on high. Great for HD movies. $50
http://www.newegg.com/Product/Product.aspx?Item=N82E16823126022 Nice fairly quite slim keyboard. I atually own this keyboard for myself. ^_^ $20
http://www.newegg.com/Product/Product.aspx?Item=N82E16826104033 Decent wireless mouse with batteries lasting up to 8 months. $20
http://www.newegg.com/Product/Product.aspx?Item=N82E16836121010 Powerful speakers good for music and movies some games. $48.99
all together it comes to $740.39 I remained under the budget and it will do exactly what you want it to do with no problems. You asked for intel I did intel. You asked for EVGA I did EVGA . no if's ands or buts. this will be your best bet for high speed web surfing and and movie burning , and the music will be great as will the movies.
BTW did you need the operating system or do you already have that? as it tends to get VERY expensive for the OS.
shouldnt i get 4 gb of ram...cause i dont think 2 is enough because the computer i have now isnt relaly running quiet fast enough on 2 gb ram..... it maxes out alot
Yeah I recommend 4 gigs , I just went with the 2 gigs for the moment because its the cheapest low latency low voltage I could find , and thanks for the compliment. if its your answer please list it as so in the thread. <3 But yes 4 gigs Veerrrrrrrry good.
