Building i5 2500k Gaming Computer. need Help. First Time
mikeu5717
6
Hey all. Been spending hours looking up stuff and getting good parts for my build. Getting it Off NCIX.Com. Just need sum help making sure this is all good and everything looks good :)
LG GH22NS70 Super Multi 22X SATA DVD Writer Black OEM
OCZ Agility 3 60GB 2.5IN SATA3 Sandforce SF-2281 SSD Solid State Disk Flash Drive
Western Digital WD Caviar Blue 1TB SATA 6GB/S 7200RPM 32MB Cache 3.5IN Hard Drive OEM
Seasonic S12II 520W EPS12V 20/24PIN ATX Power Supply Active PFC 80+ Bronze 6+8PIN PCI-E W/ 120MM Fan
Azza Solano 1000R Black Full ATX Tower Case 10X5.25 8X3.5INT 2X230MM Red LED Fans & Window No PSU
AMD Radeon HD 6870 900MHZ 1GB GDDR5 4.2GHZ PCI-E 2 X DVI HDMI 2 X Mini Display Port
G.SKILL Ripjaws X F3-12800CL9D-8GBXL 8GB 2X4GB DDR3-1600 CL9-9-9-24 Memory
Gigabyte P67X-UD3-B3 ATX LGA1155 P67 DDR3 3PCI-E1 2PCI 2PCI-E16 CrossFireX SATA3 USB3.0 Motherboard
Zalman CNPS7700-CU LED CPU Heatsink Fan Cooler LGA1156 1155 775 939 940 1000-2000RPM 22.7-37.1DBA
Intel Core i5 2500K Quad Core Unlocked Processor LGA1155 3.3GHZ Sandy Bridge 6MB
Let me know what you think. I wanted to get a cheaper Motherboard cause I don't plan on using 2 Video Cards. Any Suggestions let me know.
Yeah, get a good 650W PSU instead of the fairly small 520W and if you can afford it get a 6950 GPU, because you can unlock it to a 6970. Everything else looks good! What OS are you going to use?
Maybe a Z68 board, GA-Z68A-D3H-B3 is similar.
Different heatsink, Hyper 212+.
Maybe a Crucial m4 64gb instead of the OCZ Agility 3.
That PSU is fine for your build, but a 650W wouldn't hurt either.
Also, that case is a bit sexy.
Good choices. The reviews on that PSU are excellent. I have the modular 620W version and it is great!
I used NCIX. Use shopbot.ca to check out your parts for the best price and use NCIX's price match feature to get the best price. For example, the i5 sells at NCIX for $238 where you get get it at newegg.ca or directcanada.com for $219.99
Hope that helps!
