Building my dad-in-law a ultra-low-end PC. Need advice.
PlymouthJoseph
372
Okay, currently... My dad-in-law has a PC which he has had since the 2005s (I think) and he is always complaining that it's too slow and everything, but instead of fixing it... I'm gonna build a very low end PC from some old hardware I have lying around here at home.
We did have a old FX-4100 system for guests to use, but has since been discontinued for an upgrade, so I was thinking about using that. It currently has no RAM, case, PSU or GPU... But I do have a extremely old GPU up on a shelf. This is a MSI 8940 Ver: 200 (RD8940-200-002) I got this from when my dad was throwing his old PC away, and I said I would keep it, but instead I ripped it apart and salvaged what I could and "experimented" on everything.
Anyway... I am wondering if I could build a super-low-end PC, but what I wanna know is wither the iGPU on the motherboard would be faster than the MSI GPU... And if so... Would he be able to play Facebook games on it and other flash games without much issue?
He currently has 3 unused PCs currently being used as door stoppers and I am gonna try and find the most powerful PSU out of them all and use that to power the system... If possible. The motherboard is a M-ATX Gigabyte GA-78LMT-USB3 so it isn't very big... But I know that AMD CPUs are quite power hungry when it comes to it.
Thanks for taking your time to read this and I hope for a solution because I cringe every time I see him waiting for a flash game to load on his current PC. (Oh, it is also running WIndows Vista 32bit)
P.S: Use these links to view the GPU, just in case you cannot find it anywhere on the Internet.
https://drive.google.com/file/d/0By7ttLpsxRWCTFJ3VzFqbUJ6cXc/view?usp=sharing
https://drive.google.com/file/d/0By7ttLpsxRWCMGl2bkdnU2gyQUE/view?usp=sharing
https://drive.google.com/file/d/0By7ttLpsxRWCWnlvV1FwTXg4cDg/view?usp=sharing
https://drive.google.com/file/d/0By7ttLpsxRWCX1JqeGFoZXdNMzg/view?usp=sharing
- Joe (PlymouthJoseph)
Thats just the MSI part number, if you google the part number you can see its a X300 gpu card.
http://www.cnet.com/products/msi-rx300se-td128e-graphics-card-radeon-x300-se-128-mb/
That isn't bad... But I am hoping to pay nothing for this. But if it comes to it... I will.
Also, you didn't answer what would be better? The iGPU on the motherboard or the GPU.
What would be the cheapest 120GB SSD I could buy?
Where are you based?
England. <3
Ah same.
THis offer is on today
http://www.ebuyer.com/720808-ocz-trion-100-240gb-sataiii-2-5-inch-ssd-trn100-25sat3-240g
Or this 120gb one for £35
http://www.ebuyer.com/720809-ocz-trion-100-120gb-sataiii-2-5inch-ssd-trn100-25sat3-120g
You think 120GB will be be enough as a boot drive? He is 63 years old and often forgets to delete things... I will be using his old HDD as storage but thats besides the point.
Thats true... But you said the 240GB is on offer today... And I don't currently have the money at the moment. So the offer the may expire by then.
That is true.
So, buy the SSD, use the GPU instead of the iGPU and all should be good?
Yeah sure, so the built in graphics is Radeon HD 3000, that card is X300.
Looks to me like any of the Radeon HD 3000 series are above the X300 series.
http://www.tomshardware.co.uk/gpu-hierarchy,review-33383.html
This group is 2 tiers above the group with X300
Integrated: HD 3200, HD 3300, HD 4200, HD 4250, HD 4290, HD 6250, HD 6290
Wait... X300? This is gonna sound stupid, but where does it say that on the MSI 8940? Guessing it's the same physical GPU or...
Oh, that is fair enough then. Sorry if I came across a bit aggressive then, that was 100% unintentional.
So using the iGPU on the Gigabyte GA-78LMT-USB3 Ref: 4.1 will be faster than the GPU. So, all I need is a SSD and he should be ready to rock.
