building my first computer i want to know if the parts i chose are compatible with eachother
Yeah 750W would be just as good and would also allow breathing space should you want to add more or upgrade components on the future. 650W is probably the minimum you should get.
I don't have any experience with that brand so cannot say whether they're any better or worse. However all the reviews and ratings I have seen are very good so i'm sure that would be just fine!
hey max thank you for answer i already have old GPU that i am going to use its evega 650 TI boost supercloacked
i was wondering if this is good PSU too http://www.newegg.com/Product/Product.aspx?Item=N82E16817151107
because its may be more expensive on Newegg but its actually cheaper on my place thanks
(they have only the 750 version is that fine too) ?
