So I am beginning the path that most of you have probably already gone down. But just for reference lets state my limitations. I am a high school student who works part time so my budget is around $520 or less. I like to game but the normal laptop that I have just barely does what i want to do gaming wise. Im not to picky with graphic quality obviously sense i have used a craptop to game on, which means i use the lowest settings possible, so maxed settings is not that important to me. I mostly play TF2 (Main Game), borderlands 2, Batman Arkham Series, but the frames in tf2 are very low in the 20-30 fps range, along with constant updates keeping it in that range and sometimes it dips lower. So I have decided I want to build a desktop. As stated above I have a $520 budget and the case i plan to use is a HAF 912 and I am looking for the most bang for my buck. Also just because my budget is $520 that doesnt mean I am not open to good cheaper builds under $500 (like $430-$500). I am mainly looking for performance, like smooth high fps, in my main game (TF2) with maxed settings if possible. I have done some research like using Logical Increments to help me learn a little but i need personal assistance to help sort all possibilities.
Notes:
Have a case : HAF 912
Have a mouse : Razer Deathadder 2013
Have a keyboard : Nothing special just your basic USB keyboard, if your have good suggestions on good perforance/price keyboards post them please.
Have a monitor : Nothing really special however but it has good resolution.
Notes:
