Building my First Custom Gaming PC Help Is Very Much Needed!
Asuto
6
I need to know if these are compatible with each other and what I should replace them with, max $2500. Also need to know what to use as cooling for the computer! All support is appreciated, thank you! PC:
Raidmax ATX-605BT ATX Full Tower Case $110
Intel® Core™ i7-4790K 4.0 GHz 8MB Intel Smart Cache LGA1150 $339
Corsair H100i GTX 70.7 CFM Liquid CPU Cooler $150
ASUS SABERTOOTH Z97 MARK1 ATX $295
Corsair Vengeance 16GB (2 x 8GB) DDR3-1600 Memory $113
Samsung 850 Pro Series 1TB 2.5" Solid State Drive $600
Samsung Spinpoint F3R 1TB 3.5" 7200RPM Internal Hard Drive $125
EVGA 04G-P4-2978-KR GeForce GTX 970 4GB 256-Bit GDDR5 PCI Express 3.0 x16 SLI Support FTW ACX 2.0 Video Card $455
EVGA 750W 80+ Bronze Certified Semi-Modular ATX Power Supply $100
Total: $2288
Also if I'm missing any component or you have a video that can teach me to build a pc like this, please reply with info!
drtoast
1,287
108
I'd drop the size of the SSD down to a minimum of 250gb, halve your ram to 8gb, go air cooling for half the price, get a midtower case (nice roomy one with airflow is a 300r. and use the combined savings for a second 970 to SLI for the best performance. maybe even take an i5 if you dont wanna stream, or xeon e3 if you fancy the power of the i7 for less money.
drtoast
1,287
108
keep to your thread, dont jack.
Similar threads
