this will be my first build so I have some questions
my first question is should I attach my liquid cooling radiator to the top or on the front? and where do my fans go facing inside or on the outer side of the radiator?
my second question is there anything that I'm missing from the build?
I'm getting thermal paste and the anti static wrist strap and have the screw drivers and I have a USB thumb drive with windows 10 installed. anything else?
my third question is their any video you would recommend? I looked at quite a few, but couldn't tell which one gives the best information and shows it the least complicated way.
thanks for taking the time to help me out, I'm super excited to put this together and start playing with the master race lol.
https://www.newegg.com/Product/ComboBundleDetails.aspx?ItemList=Combo.3698365
Corsair Crystal Series 570X RGB
Intel Core i7-7700K Kaby Lake Quad-Core 4.2 GHz
MSI Z270 GAMING PRO CARBON LGA 1151 Intel Z270 HDMI SATA 6Gb/s USB 3.1 ATX Intel Motherboard (Model:Z270 GAMING PRO CARB)
SAMSUNG 850 EVO 2.5" 500GB SATA III 3D NAND Internal Solid State Drive (SSD)
G.SKILL TridentZ RGB Series 16GB (2 x 8GB) 288-Pin DDR4 SDRAM DDR4 3200 (PC4 25600)
Corsair Hydro Series H100i V2 Extreme Performance Water / Liquid CPU Cooler. 240mm
ASUS ROG GeForce GTX 1080 STRIX-GTX1080-A8G-GAMING 8GB 256-Bit GDDR5X PCI Express 3.0 HDCP Ready Video Card
EVGA SuperNOVA 750 B2 110-B2-0750-VR 80+ BRONZE 750W Semi Modular
[/listNum]
[/listNum]
