Hello everyone, I'm going to build my first PC in a couple of months. I've already done a lot of research on the subject and I've been a computer nerd since I was a little kid, I loved taking them apart and seeing what was inside. I know about making sure everything is compatible etc, all the basics I have covered and I believe I should have no problems figuring out how to piece everything together by myself. I know there are a bunch of threads asking questions about first time builds, but I didn't want to take over those threads with my abundance of questions ![Smile :) :)](/data/assets/smilies/smile.gif)
So I'm going to center my build around a Core-i5 3570k CPU, with a GTX 660 GPU, and 16GB of RAM. My budget is preferably around 1000$ although I'm willing to spend a bit more to make sure I can play the latest games on the highest settings. I'll be buying it piece by piece as I can afford it so it'll take a few months to get all the parts I need to finally start building. Skyrim is a game I want to be able to run on Ultra with a bunch of mods making the graphics even better. The main games I play are Skyrim, Starcraft 2, Mass Effect, and Dead Space. I also like to dabble in Android development which is why I'm going to stick 16GB of RAM in my system. Being able to run a VM to build Android from source while still doing things on my host computer would be very useful so I can continue using the browser to look things up as I run into problems, edit files in notepad++, etc. I've never owned a high end PC before, so I've only been able to get a taste of what good PC gaming should feel like. I'm sure after I finally own a high end computer, I'll start buying and playing a lot more PC games on Steam.
Will a GTX 660 and Core-i5 3570k allow this on a 1080p monitor? I'm also looking for help in deciding on motherboard's, which is probably the piece I know least about (not to say I know nothing, far from it). The features I'm looking for are USB 3.0 support, SATA 6Gb/s, UEFI BiOS, and preferably with a good wireless chip build in although I'm willing to buy a seperate networking card to get the best Wifi performance possible. I already know I'll need an LGA1155 board to support the Core-i5 Ivy Bridge. Also, regarding the RAM - is it better to have 2x8GB or 4x4GB to make 16GB? I do plan on overclocking the CPU a bit, and installing a premade water cooler to help keep things cool. SLI support in the mobo would be optimal, since I may expand to dual monitors at some point in the future and it would be nice to have the option to SLI 2 GPU's to get the best performance possible. I was thinking I should get a 7-800 watt PSU, what do you guys think? I'm simply going to get a 1TB 7200 RPM HDD at first, and later down the road I'll add in an SSD for the OS and my most used programs. What would be the best bang for your buck HDD and SSD? Regarding the SSD, I'll probably get a 128GB SSD.
My budget of 1000$ is for the computer itself, not including the monitor, keyboard etc. If I can get a system for slightly cheaper that can still play the games I want to play at the highest settings, that would be best. I'm a 19 year old making 12$ an hour, so the further I can make my money stretch, the better, which is why I came here to ask experienced builders to recommend some builds/parts so I can get the best bang for my buck, while ensuring that all the chosen parts will be compatible with each other. I plan on running Windows 8 for the OS, and will probably also install Linux Mint in a dual boot.
Also, I live in Canada, is newegg.ca the cheapest/best place for parts?
Thanks for taking the time to read my abundance of questions!
