Building my first gaming pc please help
fandongames
40
Ill jump right in. My budget is around $1600 us dollars. I do not need a keyboard, mouse, or monitor. I do need an os. I really want to try to have in it the I7 4790k and the gtx 980. I want to future proof it as much as possible because I don't want to have to upgrade it for a while. If it doesn't make too much of a difference I could do with a little less than the 4790k and gtx 980 but hopefully not too much less. I only plan on using this computer for hardcore gaming and video editing/recording.
for those who didn't see this part I a;ready have the MONITOR, KEYBOARD, AND MOUSE. I DO NEED AN OS The who builds im looking at now are http://pcpartpicker.com/user/fandomgames/saved/77jRsY and http://pcpartpicker.com/user/fandomgames/saved/Y4WJ7P I do not plan on 4k gaming but the budget is a little bit of a stretch on the 1700 one
You should have no problem with your budget.
Post a prospective build and you will get many comments.
What are your possibilities that you will buy a 4k monitor or want to play triple monitor games.
Those options require serious graphics capability.
If there is a case you love, start with that. You will be looking at it for a long time.
Here is a red/black build. It uses quite a few rebate's though so let me know if that's a problem.
CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor ($336.74 @ SuperBiiz)
CPU Cooler: Phanteks PH-TC14PE_RD 78.1 CFM CPU Cooler ($64.99 @ Newegg)
Motherboard: ASRock Fatal1ty Z97X Killer ATX LGA1150 Motherboard ($119.99 @ Micro Center)
Memory: G.Skill Sniper Series 8GB (2 x 4GB) DDR3-2133 Memory ($74.99 @ Newegg)
Storage: Crucial MX100 256GB 2.5" Solid State Drive ($109.97 @ SuperBiiz)
Storage: Seagate Barracuda 3TB 3.5" 7200RPM Internal Hard Drive ($101.99 @ NCIX US)
Video Card: MSI GeForce GTX 980 4GB Twin Frozr Video Card ($585.91 @ Newegg)
Case: NZXT H440 (Black/Red) ATX Mid Tower Case ($109.99 @ Micro Center)
Power Supply: XFX 650W 80+ Bronze Certified ATX Power Supply ($49.99 @ NCIX US)
Operating System: Microsoft Windows 7 Home Premium SP1 (OEM) (64-bit) ($89.98 @ OutletPC)
Total: $1644.54
Generated by PCPartPicker 2014-10-06 22:09 EDT-0400
I don't plan on using any mmail and rebates so it's not really going to work
