GPU: ASUS TUF Gaming X3 Radeon RX 5700 XT OC Edition 8 GB GDDR6, Space-grade Lubricant, IP5X Dust Resistance, Auto-Extreme Technology, Metal Back Plate, TUF Compatibility, 144-Hour Validation
CPU: AMD Ryzen 5 3600 Processor (6C/12T, 35MB Cache, 4.2 GHz Max Boost)
RAM: CORSAIR VENGEANCE RGB PRO 16GB (2x8GB) DDR4 3600 (PC4-28800) C18 Desktop memory – Black
Motherboard: MSI B450 TOMAHAWK MAX Motherboard ATX, AM4, DDR4, LAN, USB 3.2 Gen2, TYPE-C, M.2, RGB Mystic Light Sync, HDMI, DVI-D, AMD RYZEN 1st, 2nd and 3rd Gen Ready
SSD: Western Digital WDS500G2B0A WD Blue 3D NAND Internal SSD 2.5 Inch SATA, 500 GB
Cooling: Cooler Master Hyper 212 RGB Black Edition Cooling System - Stylish, Colourful and Precise - 4 Continuous Direct Contact Heat Pipes with Fins, SF120R RGB Fan
Case: Corsair SPEC-DELTA Carbide Series, RGB Tempered Glass Mid-Tower ATX Gaming Case - Black
Power supply: Corsair VS650 650 W Active PFC 80 PLUS Certified Power Supply Unit - Black
If I need to add, change or remove anything feel free to tell me whatever I should change
