[SOLVED] Building my first PC, does everything match?
Mar 16, 2019
Here is the PcPartPicker list, just wanted to know uf everything will work together bcuz i really dont trust PcPartPicker, as i dont want to have a part that foesnt fit in the case. side note; i know ill need fan splitters for the case fans, any recommendations on those?
Everything works fine together. However, even if this is not your question, i would advise you to change ssd. The a400 isnt very good. Switch to the mx500 250gb. Any fan splitter ought to do.
Mar 6, 2019
24
