So I am going to build my most expensive PC ever. I've gotten pretty expensive ones, but I had them made at CyberPowerPc.
I am a programmer, but I am NOT good with hardware. However, I've done some research, and I believe to the best of my knowledge that all of these things are compatible.
I cannot think of any scenario where I could possibly use more than 16 cores in my GPU, which is why I went with the 16 core threadripper. As a programmer, I know a bit about threading, and I just can't imagine that a game or normal app would be able to utilize more, even if it had multi-core support programmed in. But then, most games don't need as much from the CPU anyway. Is this a solid assumption?
I already have the monitor, luckily.
What you think? Can I do better? Any mistakes? General thoughts? Thanks!
https://pcpartpicker.com/list/Mgqjw6
