Building my first pc help!
Nibagg
Heya! As the title says im planning to build my very first pc, but will this build work or will something be wrong?
parts
GPU-Gigabyte Nvidia GTX 1050Ti WF2 OC 4GB GDDR5
CPU-AMD Ryzen 5 1500X
RAM-HyperX FURY DDR4 8 GB 2400 MHz
MTB-MSI B350 TOMAHAWK
PSU-EVGA 600 W1, 80+ WHITE 600W
HDD-WD Blue 1TB Desktop Hard
CASE-Aerocool Aero-500
These are the parts im thinking of. Is something wrong or will everything work out? Do something miss?
Thank you!
No, the CPU clock speed won't matter but as you can see in the article I posted that there's almost a 15 FPS difference comparing 2133 to 3200mhz.
the psu is low quality, get a GOOD 450w unit not a mediocre 600w one
you should also avoid msi mobos, asrock have better models for great prices
really want at least 2666 ram as well for ryzen
