Q QuadPick Reputable May 7, 2014 5 0 4,510 May 7, 2014 #1 Is an Asus maximus vi hero compatible with this graphics card http://m.newegg.com/Product/index?itemnumber=14-121-710
Solution Tradesman1 May 7, 2014 If it's a PCI-E card yes, is this it? http://www.newegg.com/Product/Product.aspx?Item=N82E16814121710&Tpk=14-121-710 then Yes
T Tyrique Rice Reputable May 4, 2014 19 0 4,510 May 7, 2014 #2 The link that you provided when i click it just take me to the newegg home page not the card you are asking about Upvote 0 Downvote
Tradesman1 Legenda in Aeternum Jun 5, 2013 67,881 41 126,960 May 7, 2014 Solution #3 If it's a PCI-E card yes, is this it? http://www.newegg.com/Product/Product.aspx?Item=N82E16814121710&Tpk=14-121-710 then Yes Upvote 0 Downvote Solution
unknownofprob Illustrious Oct 3, 2013 8,409 0 38,960 May 7, 2014 #4 it will be, if the card says PCI-E X16 2.0/3.0 slot required, just put it in the first long red slot with the clip, it'll work to it's best capability. Upvote 0 Downvote
