[SOLVED] Building my first PC
Aug 12, 2020
5
Hi everyone!
I am a complete novice, and I have no idea what I'm doing. I would really appreciate some help.
Here's what I have for now:
THERMALTAKE Smart RGB 700W
G.SKILL 16GB Aegis DDR4 3200MHz CL16 KIT F4-3200C16D-16GIS
MSI Radeon RX 580 ARMOR 8G OC RX 580 8GB GDDR5 OC PCIE
ASUS PRIME B360M-A
LG 24MP59G-P
PATRIOT 512GB P210 SATA 3 2.5" P210S512G25
INTEL Core i3-9100F 3.60GHz LGA-1151 300 BOX Intel hűtő ventilátorral
+1 tb hdd
Any thoughts? Any peace of advice would be greatly appreciated.
Thanks in advance!
It is best to post your parts list before you buy.
That said, while one might prefer other parts, I see no incompatibilities so you are ok to build.
For a first time builder, Here are a couple of canned thoughts on the subject:
----------------how to mount the stock Intel cooler--------------
The stock Intel cooler can be tricky to install.
A poor installation will result in higher cpu temperatures.
If properly mounted, you should expect temperatures at idle to be 10-15c. over ambient.
To mount the Intel stock cooler properly, place the motherboard on top of the foam or cardboard backing that was packed with the motherboard.
The stock cooler will come with paste pre applied, it looks like three grey strips.
The 4 push pins should...
The 4 push pins should come in the proper position for installation, that is with the pins rotated in the opposite direction of the arrow,(clockwise)
and pulled up as far as they can go.
Take the time to play with the pushpin mechanism until you know how they work.
Orient the 4 pins so that they are exactly over the motherboard holes.
If one is out of place, you will damage the pins which are delicate.
Push down on a DIAGONAL pair of pins at the same time. Then the other pair.
When you push down on the top black pins, it expands the white plastic pins to fix the cooler in place.
If you do them one at a time, you will not get the cooler on straight.
Lastly, look at the back of the motherboard to verify that all 4 pins are equally through the motherboard, and that the cooler is on firmly.
This last step must be done, which is why the motherboard should be out of the case to do the job. Or you need a case with a opening that lets you see the pins.
It is possible to mount the cooler with the motherboard mounted in the case, but you can then never be certain that the push pins are inserted properly
unless you can verify that the pins are through the motherboard and locked.
If you should need to remove the cooler, turn the pins counter clockwise to unlock them.
You will need to clean off the old paste and reapply new if you ever take the cooler off.
Clean off old paste with alcohol and a lint free paper like a coffee filter.
Apply new paste sparingly. A small rice sized drop in the center will spread our under heat and pressure.
Too much paste is bad, it will act as an insulator.
It is hard to use too little.
MY build process:
Before anything, while waiting for your parts to be delivered, download
and read, cover to cover your case and motherboard manual.
Buy a #2 magnetic tip philips screwdriver.
I find it handy to buy a power switch like this for testing.
https://www.ebay.com/p/4in1-PC-Powe...or-Computer/631889283?iid=142232821294&chn=ps
1. I assemble the critical parts outside of the case.
That lets me test them for functionality easily.
A wood table or cardboard is fine.
2. Plug in only the necessary parts at first. Ram, cpu, cooler, psu.
Do not force anything. Parts fit only one way.
Attach a monitor to the integrated motherboard adapter if you have one, otherwise to the graphics card.
  1. If your motherboard does not have a PWR button, momentarily touch the two pwr front panel pins with a flat blade screwdriver.
  2. Repeatedly hit F2 or DEL, and that should get you into the bios display.
  3. Boot from a cd or usb stick with memtest86 on it. memtest will exercise your ram and cpu functionality.
  4. Install windows.
  5. Install the motherboard cd drivers. Particularly the lan drivers so you can access the internet.
Do not select the easy install option, or you will get a bunch of utilities and trialware that you don't want. Drivers only.
  1. Connect to the internet and install an antivirus program. Microsoft security essentials is free, easy, and unobtrusive.
  2. Install your graphics card and driver if you tested with integrated graphics.
You will need to remove the graphics card later to install your motherboard in the case.
As a tip when screwing the motherboard into the posts, give the screw a small counterclockwise turn until you feel a click.
That lets you know that the screw will engage properly.
Make a note of how the graphics card latches into the pcie slot.
The mechanism will be hidden under the card and may be difficult to work if you have not previously checked how.
  1. Update windows to currency.
  2. Only now do I take apart what I need to and install it in the case.
  3. Now is the time to reinstall your graphics card.
Two important things:
1. When you drop the processor onto the socket, drop it in cleanly.
Do not smoosh it around to get it seated or you will damage delicate socket pins.
2. When you install windows on the ssd do NOT have any other drives connected.
If you do, windows places a hidden recovery partition on it making it essential to booting.
You will not easily be able to remove the drive in the future.
That PSU needs changing out regardless of what the sticker on that unit says in terms of power.
Mind stating where you're located? You might want to also read through his thread and add more information to your current thread.
Thank you for the welcome and the answer!
I'm in Bosnia and Herzegovina. I'll definitely check out other options for the PSU.
Appreciate it!
MY build process:
  4. Install windows.
Thank you, these mean a lot!
I agree that the PSU needs changing.
If I understand correctly, you already have these parts right? Or have you not purchased them yet?
Thanks a lot!
Nope, haven't bought them yet, still exploring my options. What PSU would you recommend with this setup? I'm also thinking of a better PCU...
