Building my first serious zon
Ryan
551
Archived from groups: alt.games.diablo2 (More info?)
I've decided to start my first real amazon, and I need some advice about
what to do with it. I want to use a build that will require minimal
'rushing' (i.e I want to be able to solo most of the game), so I have some
questions.
1) Would a javazon or bowazon work better for solo play?
2) The javazon build that seems most popular right now is lightning
fury...so if I build one, which of the synergies should I focus on, and what
is an appropriate point spread for passive skills?
3) The other build I've heard about are multi-shot/ice arrow bowazons. What
exactly goes into building one, or is there a 'preferred' bowazon build.
Since I'm totally new to to amazons, I'd appreciate any help.
If you want a zon that can solo through most of the game, you'd probably be
better off going with a bowazon.
I'd suggest maxing Guided Arrow and Valkerie, with about 4 or 5 points in
Multishot and same for Strafe. You should get +skills items at some point
that will boost these up.
Other skills you can add to taste, but one thing to consider is that if you
max Frozen Arrow you'll need a bow that does magic damage (or gear that adds
elemental damage) to take down the cold immunes.
It's not too bad, my bowazon is lvl 80 with a Buriza, and I'm keeping my
fingers crossed that she finds a nice WF one of these days...
Sorry for the impartial list regarding skills, I'm still on my first cup of
coffee.
-Cym
Ok, I was sitting on my hands, because my regular LoD (as opposed to
playing in mods) Bowazons are/were struggling at the moment (my SP
Slayer's life just got a *lot* easier when she found a Kuko), but
since the Bowazon (or more specifically the Strafeazon) is about the
only character I seriously play, I can't here.
That said, due to my current problems (my ladder Zon seems to be stuck
just before the Ancients in Hell, I really need to talk my friend away
from WoW (*and* be able to connect to BNut, but I could do that by
hooking up the old computer) to help finish her up), I can't say
without my doubts that I think they're the easiest to *solo* through
the game with. Heh, as a matter of fact, I've been thinking of
starting a Javazon, but really feel I should get at least *one* of the
non-Bowazon characters into Hell first ;-)
This is the one that got me to speak up. Why max Guided? It was great
in 1.09, but now that it doesn't pierce, I haven't found a reason to
add more than one hard point to it. Oh, and I *always* max Strafe, but
I'm weird that way ;-)
Not with a decent level of Strafe ;-) The only drawback is, in 1.10
they added a "feature" where if you get hit and go into hit recovery
(apparently, I haven't heard anyone else talking about this and it
doesn't happen *every* time I get hit) the Strafe animation continues,
the arrows still fly, but they don't do any damage and thus don't
leech, and that can make you be seeing red all too soon. Quite
annoying :-(
You could also go with a Kuko, I haven't gotten it into Hell yet but
it sure is making a *big* difference in Act 2/NM.
>coffee.
>-Cym
So am I, actually just getting the first full cup now ;-) Your Burrito
may be the difference there, I've never found one and play all of my
SP characters pure, so the only time I've managed to play with one is
with one of my first ladder characters, who was given one by a friend
at just about the same time another friend gave her a Goldstrike Arch.
When I play her (most of the time when I *can* connect to BNut I'm
playing my ladder characters) I'm still trying to figure out which one
I like better.
My opinion on skills:
Max Strafe and eventually Frozen Arrow and Valk (both of these will do
well early on with only a couple of hard points, I add to them as it
becomes apparent that they *need* to have more points)
Critical Strike, Penetrate and Pierce to about the point where they're
at or just below 50% with +skills (the point of diminishing returns).
Dodge, Evade and the other one (Avoid? Something like that) you *want*
around 50%, but 40% or so is doable, depends on how high you're taking
the character and thus how many points you have to play around with.
My current builds are avoiding the fire arrow leg of the tree, but
there *are* times when Immo can be very handy.
The rest of the skills in the (non-fire) arrow and passive trees only
one hard point (I always add the point to Penetrate, maybe I should
try a build where I don't, as AR never seems to be a problem), unless
I'm forgetting something which is *quite* possible. Yes, that includes
Multi-Shot for me, I was convinced to play through most of NM and Hell
using it with my level 99 Bowazon in AR (caveat on the 99, once
through AR and DotD at players one in 1.09 was enough to get her there
(made 99 just before Baal in DotD)) and was convinced that it isn't
worth using, Strafe is just too much better, IMNSHO ;-)
ald
reply via email to ald_007_1999 at yahoo dot com
> questions.
Sounds good so far :).
A bowazon certainly depends more on equipment than a javazon. Unless you
already have a real nice bow, go with the javazon. Just make sure you
can live with all the repair trips to town.
All the synergies to LF increase the damage only by 1%. Not worth it.
For solo hell play, you need a way to handle lightning imunities. Go for
Poison/Plague Javelin (needs lots of +skills, around 10 is ok) if you
want to make a pure Javazon. Or make a hybrid with Freezing
Arrow/Strafe/Multishot/Immolation Arrow/whatever.
I managed to solo HC hell with my LF/Plague Javelin Zon, so I can say
it's doable, and not too difficult. Of course, Plague Javelin isn't a
fast killer, but you can do something else (switch to LF, run away from
the Ancients) while the poison does the job.
For passives: a max Valk is quite strong. If you have spare points place
them here. Unless you play HC, you can leave Dodge/Avoide/Evade at 1.
With some +skills, Critical Strike, Penetrate and Pierce are worth one
point each. If you plan to farm Cows, Pierce should be as high as possible.
I haven't played bowazon much lately, somebody else fill the gap please.
Hannes
Thanks for the advice, which type of zon I go for will probably be
determined by what gear I can round up beforehand, so I'm grateful that
someone people covered both.
I'll be sure to post once I hit around hell to say how it's working out.
Hannes Brunner wrote:
>> about what to do with it. I want to use a build that will require
>> minimal 'rushing' (i.e I want to be able to solo most of the game), so
>> I have some questions.
>> and what is an appropriate point spread for passive skills?
>> What exactly goes into building one, or is there a 'preferred' bowazon
>> build.
I have a fun bowazon that's made it to lvl 95 and still going on HCL.
She's a strafezon that uses procs to boost killing speed. The main
problem is that she's very gear dependent.
I maxed strafe, valk, penetrate (need as much AR as possible), 10 or so
in GA for fast movers, 10 in critical strike and 10 in pierce. She has
strength to carry gear, enough vitality to have 1K life, everything else
is in dex, around 400 total.
Her gear
Windforce -with a 38% ED jewel
Fortitude Wire fleece (used lionheart for along time first)
Kira's for resists
Laying of hands - Holy bolt proc
Atma's scarab - amp damage proc
Ravenfrost
carrion wind - twister proc and LL
Tgods - FOH proc and light absorb
Gore Riders - Open wounds, crushing blow
Use demon limb for additional AR.
I know it's a pricey build, but she can solo anywhere in the game. The
only monsters she has problems with is Stygian witches on level three of
the worldstone, they are PI and ranged. She can't kill them till amp
goes off.
On Tue, 18 Jan 2005 22:50:04 GMT, Bullet
Procs?
ald
On Thu, 20 Jan 2005 13:18:03 +1300, "~misfit~"
<misfit61nz@hooya.co.nz> wrote:
>When I was playing 1.09 I had a Zon who got to about lvl 85 with a
>(Shael'ed) Buriza and I too dreamed of a Windforce. When I finally got one I
>used it for a few days, then went back to the Buriza. The crowd-control of
>the Buriza's cold when strafing was just too good to give up. I put a Hel in
>the Windforce and gave it to a Rogue merc, she really liked it.
>~misfit~
You want crowd control? Try the Windforce with maxed Frozen Arrow
(somewhere between level 30 and 35, by the time I found it) ;-) Yeah,
this was in AR (Ancestral Recall), she *finally* got a Windforce out
of the Infector just before she got to Baal in AR (Baal's "friend"
dropped a better (version 1.08?) one for the Rogue in DotD, but I was
pretty much through playing her at that point), but *man* that bow was
awesome. Note that, as I said elsewhere, I've only had one Burrito to
play with, and that's on a lower-60's level Bowazon in Act 1 of NM,
IIRC, but her Goldstrike Arch seems to work just as well as the
Burrito, and she (or *any* of my Bowazons) would still *love* to have
a Windy ;-)
ald
<snip> > Your feelings about Strafe sound a lot like mine about Multi-Shot.
Of
> course, part of my objection to MS has been invalidated, now that
> Strafe also only deals 3/4 damage. Hmm, you've got me thinking I need
> to try out maxed Guided on one character, probably the AR (Ancestral
> Recall) one I'm currently working on, since she'll miss the required
> skill points the least, perhaps I'll have to try MS again also,
> probably on the Nez Bowazon who's currently bemoaning the lack of
> crowd control (or any real use for mana) until level 36.
It's worth a try, that way you can say you've done it. ^ ^
>>> annoying :-(
>>Another reason I don't max strafe. :)
> You don't see this with MS?
Something wierd happened to me in the Durance of Hate where some of my MS
arrows weren't seeming to hit the Stygian Dolls. Other than that, MS has
been a blessing for me.
>>All in all, it all comes down to personal preference. I respect your view
>>on maxing strafe, but IMHO maxed GA works better mixed with about 5 or so
>>points in Multishot. Of course, + skills gear makes all the difference.
>>Thanks for sharing your views, it's refreshing.
>>-Cym
> Agreed, and as I stated above you're definitely making me rethink my
> options. Only 5 or so in MS, huh? I've been told you needed at least 9
> or 10, but that *was* back in 1.09.
> ald
Yep, as long as you have at least +1 bow skills somewhere, that's all you
really need. I could see why people would say 9 or 10 in 1.09, but it's
really unnecessary these days.
-Cym
> I
> in
> ~misfit~
That's cool that the Buriza worked better for you, but I found I needed the
extra damage of the WF when I was in Hell. However, I did keep a Buri on
switch. :)
Yeah, I'm planning on seeing what she has in the way of skill points,
when her turn comes around again (should be pretty soon, IIRC Nez
comes up after regular LoD, which is the current rotation spot.
Unfortunately, the LoD Amazon has talked me into giving her a second
game in this go-round, as right as she finished clearing the first
(wrong) leg of the AS last night, I somehow lost sound on the computer
(not just the game). It fixed itself as it was shutting down for a
re-boot, but by then it was too late to start up another game).
Unfortunately, in Nez, MS starts out needing 3 skill points for the
first level, and increases after level 4 or 5, but she'll deal with it
Yeah, I hate it when things like that happen. I've seen my arrows
being fired behind me, when I'm aiming at a monster in *front* of me,
even using Normal attack. Some sort of BCM logic, I'm sure ;-)
>-Cym
Fair enough, I guess it *is* about time I try a different build ;-)
ald
