Building my New Rig. Would Appreciate Comments On Better Parts.
jisgore
47
Here it Is:
ASUS SABERTOOTH 990FX R2.0 AM3+ AMD 990FX $189.99
AMD FX-8120 Zambezi 3.1GHz $159.99
Western Digital WD VelociRaptor WD3000HLHX 300GB 10000 RPM 32MB $69.99
XFX Double D FX-785A-CDFC Radeon HD 7850 2GB 256-bit GDDR5 $209.99
G.SKILL Ripjaws X Series 16GB (2 x 8GB) 240-Pin DDR3 SDRAM DDR3 1866 $79.99
Total $709.95
Would You guys recommend changing any pieces. Or downgrading one to upgrade another. I'm mainly going to use this for gaming and HD movies.
Thank very Much
10000rpm drives are a hoax. they are no faster than a 7200rpm drive. Not worth the money at all.
You don't need more than 8gb RAM for any gaming at all.
If you are planing to game, get the fx6300 and an $80 mobo.
Use the extra money to get a 7870.
Gaming is 90% GPU and 10% CPU
I'm also a web developer/Graphic Designer so i kinda need the ram for photoshop and stuff. But i see your point on the CPU and the 80 mobo.
What would be The difference in performance if i change the ASUS for this one ASRock FM2A85X Extreme6 FM2 AMD A85X (Hudson D4) HDMI SATA 6Gb/s USB 3.0 ATX AMD Motherboard and change the 8 core for the 6 core you recommended
I'm very concerned as well for the motherboard durability thats why i choose this one.
Lol didn't notice about the Socket XD. Thanks.
I tweaked and i'm going to get the 7950 instead, Is there a big difference between the 7870 and the 7950?
I also changed the CPU for the one you recommended
I know that for me there will be a huge difference because what i have now is the 6670
Oh BTW will a 1200 power supply Handle all this if i buy 2 of those cards?
So running Far Cry 3 on Optimal settings on this card MSI R7950 Twin Frozr 3GD5/OC Radeon HD 7950 3GB 384-bit GDDR5 @ 2560x1600 and With the current parts that i'm buying would be breeze?
