Building my own Custom PC,how is it Any ideas?
Hassan_92
78
CPU: i5-6600
M.B: Gigabyte GA-Z170X Gaming 3
VGA: Asus Strix GTX950 DC2OC 2GD5
Ram: 8GB
HDD: 1TB 7200 64MB
Power: Green 600w
If you're going for a gaming rig I would go for a k (unlocked) CPU so that you can overclock in order to get more use out of it before an upgrade.
http://www.amazon.com/Intel-Boxed-I5-6600K-Processor-BX80662I56600K/dp/B012M8M7TY
And also I wouldn't game with a stock cooler, just my feelings, but I couldn't give someone gaming pc recommendations without an after market cooler.
http://www.amazon.com/Cooler-Master-Hyper-212-RR-212E-20PK-R2/dp/B005O65JXI/ref=pd_sim_147_1/179-9103484-1932853?ie=UTF8&dpID=518BEXKEiiL&dpSrc=sims&preST=_AC_UL160_SR141%2C160_&refRID=0D8EY9Q5XPVFKMTQA44G
Motherboard is looking good, I haven't done much research into it but from what I've seen you shouldn't be disappointed.
The video card is fine.
Is the RAM...
Is the RAM you've selected DDR4? The motherboard supports DDR4. In case you haven't here's what I'd go with:
http://www.amazon.com/Crucial-Ballistix-PC4-19200-Unbuffered-BLS8G4D240FSA/dp/B00MTSWG30/ref=pd_sim_147_20?ie=UTF8&dpID=41ab9ciClXL&dpSrc=sims&preST=_AC_UL160_SR160%2C160_&refRID=0N18AFCEGHT4TK8P3DPJ
I'd go with one stick for now so that you can upgrade without having to buy a whole new set.
Make sure you get a good HDD, this may seem weird, but HDD's tend to have a fairly high failure rate. Hitachi is a great brand, albeit more expensive. Just make sure you backup your stuff to an external periodically incase of failure.
The PSU is a rather specific component. I'm not sure why you want a green PSU with your black and red motherboard but that's up to you. If you want more info on what the PSU 80+ ratings mean check this out:
http://www.hardwaresecrets.com/understanding-the-80-plus-certification/
Take a look at this PSU and let me know what you think:
http://www.newegg.com/Product/Product.aspx?Item=9SIA3912D86700&nm_mc=KNC-GoogleMKP-PC&cm_mmc=KNC-GoogleMKP-PC-_-pla-_-Power+Supplies-_-9SIA3912D86700&gclid=CMDHn77vn8oCFRQlgQodi5cKaA&gclsrc=aw.ds
You don't need 600w at this stage though.
Let me know if you have any questions.
Good luck,
-wildi
Thanx for informations okey here we Go:
okey i agreed with CPU so from i5-6600 to i5-6600K(Unlocked) CONFIRMED:bounce:
About the RAM DDR4 The city i live have these Brands for "Ram DDR4" as below:
ADATA,G.Skill,Kingston,& Corsair (If you suggest between these would be glad to hear it)
Motherboard CONFIRMED:bounce:
VGA CONFIRMED:bounce:
About HDD yea i have 2T External always Backup,So i will be looking for Hitachi or Seagate either 1...
& about the PSU the 1 u recommended its has 600W but the Brand is the problem
The brand which are available in my Country Are as follow:
HP,Elegance,Acer,XFX,TSCO,Remax,Corsair,CoolerMaster,Green,Gigabyte,Memonex, & Huntkey
(If you suggest any of these brands above would be thankful)
before confirming anything anyhow... what will be the use of your rig?
if is for gaming which games? which resolution?
for the psu get the XFX
YOU DO NOT NEED ANY UNLOCK PROCESSOR , the new skylake locked cpu can be overclock as well now
get asrock z170 mobo or asus
I would say go with G.Skill, Corsair, or Kingston. It doesn't matter which, just make sure your motherboard supports the frequency.
I apologize for assuming you meant that you wanted a green color PSU, I've never heard of this green company. I would recommend Corsair, Cooler Master, XFX, or Gigabyte. But again, go with whichever one you want as they're all good.
Let me know if you need anything else, good luck!
My Rig will be for Gaming,Games Such as COD,Mad max,Project Cars,BF,The Crew Wild run & ect.... also all these games with 1920x1080 Resolution high settings,i dun need more then thats its enough not 4K 😀
& for PSU how much "w" u suggest 600w or 650w which 1 is better ??
about the Motherboard i guess Gigabyte is enough dont u think 😀
With those components you only need a 600 watt PSU, a 650 will just be a waste of money. This build will work amazingly for those games at 1080p, I wouldn't expect everything to run flawlessly at ultra but it should have no problem on high and sometimes medium.
Good luck!
-wildi
Yea i'll surely go with 600w tnx for information & yea 1080p is really enough for gaming Till NOW 😀 later will look for an upgrade 😀 Tnx for ur time Pal
Yea i just reviewed the ones u names above though they are very strong & its perfect,But this is my First rig for now i would go with GTX 950,but later will surely upgrade it to GTX960 or GTX980Ti tnx for advice pal :) 😀
Another Suggestion :
& btw i have changed my M.B from "Gigabyte GA-Z170X Gaming 3" TO "Asus Z170 Pro Gaming"
is this Ram Good enough for now "G.SKILL Ripjaws4 DDR4 8GB (4GB x 2) 2800MHz CL16 Dual Channel Ram"
is WD Black Color 2TB 64MB good too???
Would be thankful.....
That all looks good.
Good luck,
-wildi
